Home » Newcomers » Newcomers » Maven and eclipse not fully functional(I've installed maven but cant use it's full functions for some reason and I cant change my eclipse.ini for some reason)
Maven and eclipse not fully functional [message #769402] Wed, 21 December 2011 19:52 Go to next message
Apache Omega is currently offline Apache Omega
I'm using the Maven Apache plug in for eclipse because I'm to new to figure out the command line method but now that I've switched I'm having problems again.
my maven plug in is installed but the list for the archetype catalogs are greyed out so I cant select them.
every time I try to install a m2e connector I get this message {Problems occurred while performing installation: org/sat4j/minisat/core/AssertingClauseGenerator
org/sat4j/minisat/core/AssertingClauseGenerator}
I'm trying to point my eclipse.ini to my jdk but my computer wont let me save it (it reads access denied)
when I bring up a project and choose run-as my m2 eclipse maven options wont pop up
please please please tell me how i can fix this!!!!
Re: Maven and eclipse not fully functional [message #769439 is a reply to message #769402] Wed, 21 December 2011 22:14 Go to previous message
Russell Bateman is currently offline Russell Bateman
> problems again.
> wont pop up
The first line is confusing: you were new to the command-line method,
but you got it working after having problems, then you switched? What
exactly have you switched to? Using Maven from the Eclipse workbench?
Are all the archetypes greyed out or just some of them?
This and your other forum question this evening indicate more than just
one problem with Maven and Eclipse.
First, what platform are you trying to run Eclipse on? Where did you
attempt to install it that it cannot read from?
Second, this forum isn't for supporting Maven. You might try one or more
of the following instead:
eclipse.technology.iam
eclipse.technology.m2e
And/or also these URLs:
http://eclipse.org/m2e/
http://maven.apache.org/guides/mini/guide-ide-eclipse.html
Previous Topic:No Server View or Server Option in Preferences
Next Topic:how to config resin in eclipse
Current Time: Sat May 25 10:19:16 EDT 2013
Powered by FUDForum. Page generated in 0.01473 seconds
