Home » Language IDEs » Objectteams » ObjectTeams and WebStart
ObjectTeams and WebStart [message #688239] Fri, 24 June 2011 04:44 Go to next message
Sven Krause is currently offline Sven Krause
has anyone already used ObjectTeams in conjunction with RCP via WebStart? Is there anything special to consider or is it impossible at all?
Sven
Re: ObjectTeams and WebStart [message #688527 is a reply to message #688239] Fri, 24 June 2011 17:21 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan Herrmann
Hi Sven,
I've never written a WebStart application, so I can't tell you the details right away, but since you speak about RCP and since OT/Equinox lets you write RCP applications with OT/J I expect this to work out fairly straight forward.
Do you have experience with RCP via WebStart?
You'll have to include all bundles from the org.eclipse.objectteams.otequinox feature in your application. Since you won't install using p2 you'll have to manually add a few lines to config.ini, that might be all.
If you have a RCP-via-WebStart Hello-World I'd be happy to help adding OT/Equinox to the stack.
Why don't you file a new bug against OT/Equinox and we'll work out the details in the bug?
best,
Stephan
Re: ObjectTeams and WebStart [message #768857 is a reply to message #688527] Tue, 20 December 2011 18:49 Go to previous message
Hi again,
have you had a chance to try OT via WebStart? If so, it would be cool if you shared your results.
If not, I'd still appreciate a hint on how RCP via WebStart should work generally, so I can give it a try myself.
Stephan
Previous Topic:Project update
Next Topic:JVM options for OT/Equinox
Current Time: Tue May 28 07:09:11 EDT 2013
Powered by FUDForum. Page generated in 0.01623 seconds
