Home » Newcomers » Newcomers » plugin downloads timeout(can't get/install any plugin)
plugin downloads timeout [message #765341] Tue, 13 December 2011 16:44 Go to next message
mike  is currently offline mike
Hello All,
First off: I would appreciate if one of you could point me to a different thread on here if my question isn't appropriate for this place.
Ok, the problem is: none of the plugins install. I have done all preliminary checks and have gone to google often to find out why but no luck.
I have good connection and have made sure that my network domain isn't blocking my eclipse's communication with the outside world...
Similar to the following is what I see for all plugin install(by using "help->install" from the menu:
java.net.ConnectException: Connection timed out: connect
	at java.net.PlainSocketImpl.socketConnect(Native Method)
	at java.net.PlainSocketImpl.doConnect(Unknown Source)
	at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
	at java.net.PlainSocketImpl.connect(Unknown Source)
	at java.net.SocksSocketImpl.connect(Unknown Source)
	at java.net.Socket.connect(Unknown Source)
	at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEventCreateUtil.createSocket(SocketEventCreateUtil.java:43)
	at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:81)
	at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:73)
	at org.eclipse.ecf.internal.provider.filetransfer.httpclient.ECFHttpClientProtocolSocketFactory.createSocket(ECFHttpClientProtocolSocketFactory.java:65)
	at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
	at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361)
	at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
	at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
	at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
	at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:346)
	at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1142)
	at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:710)
	at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:889)
	at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
	at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
	at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:349)
	at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.readInto(FileReader.java:295)
	at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:80)
	at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:130)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:721)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:640)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
	at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:117)
	at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:102)
	at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82)
	at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Thanks in advance,
Mike
Re: plugin downloads timeout [message #765353 is a reply to message #765341] Tue, 13 December 2011 17:27 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
Does your workstation need to use a Proxy to get to the internet? If so, then you need to configure the proxy settings in Eclipse to route requests through the Proxy.
Re: plugin downloads timeout [message #766382 is a reply to message #765353] Thu, 15 December 2011 11:59 Go to previous messageGo to next message
dpwegener, I have made sure of that. but please list the pathway in eclipse to do the same as you would.
Thanks anyway.
Mike
Re: plugin downloads timeout [message #766502 is a reply to message #766382] Thu, 15 December 2011 17:33 Go to previous messageGo to next message
I can't tell you what to set your proxy settings to. That would depend on your network. You need to contact your network admin for that information.
Re: plugin downloads timeout [message #768751 is a reply to message #766502] Tue, 20 December 2011 12:58 Go to previous message
I am able to download plugins, I just re-installed a new copy of eclipse(indigo)
Here is what I changed in eclipse.ini to fix the proxy problem in my eclipse.
I got my proxy info from IE
-Dhttp.proxyPort=8080
-Dhttp.proxyHost=myproxy_name
-Dhttp.proxyUser=mydomain\myusername
-Dhttp.proxyPassword=mypassword
-Dhttp.nonProxyHosts=localhost|127.0.0.1
I still see the same error I posted at the beginning of this tread.
I see it when my program tries to read from a site for example:
www.javaworld.com/javaworld/jw-09-2008/jw-09-hadoop.html?page=3
Any other pointer to resolve this would be appreciated.
Mike
Previous Topic:Eclipse indigo--ReportDesign perspective missed
Next Topic:Eclipse, plugin preference loading issue
Current Time: Sat May 18 14:51:35 EDT 2013
Powered by FUDForum. Page generated in 0.08364 seconds
