| Cannot access Action in CSPEX [message #725149] |
Wed, 14 September 2011 01:33  |
Jakob Braeuchi Messages: 59 Registered: July 2009 Location: Switzerland |
Member |
hi,
we have defined our own ComponentType for EAR-Files. To build the CSPEC of the EAR-Type there is a EarResolutionBuilder class extending from AbstractResolutionBuilder.
This solution works as expected: i can view the CSPEC of an EAR and i can also invoke the defined action "pack.ear".
The problems shows up as soon as i create a CSPEX for an EAR-Component. I want to define a new action "pack.ear.ext" which uses the "pack.ear" action as a prerequisite:
Problem during meta-data refresh: CSpec ch.rtc.zpv.application:osgi.bundle$1.0.0.qualifier has no action, group, or local artifact named pack.ear
Do i have to add some "magic" to our EarResolutionBuilder to make it work or ist it a bug in Buckminster ?
thanks
jakob
| Re: Cannot access Action in CSPEX [givenCtypeId is null] [message #725565 is a reply to message #725550] |
Thu, 15 September 2011 04:17   |
Thomas Hallgren Messages: 3165 Registered: July 2009 |
On 2011-09-15 08:56, Jakob Braeuchi wrote:
> hi thomas,
> after some debugging i found the cause for the problem.
> in the method LocalResolver#fromPath
> public static Resolution fromPath(IPath productPath, String name, String givenCtypeId, IProgressMonitor monitor) throws
> CoreException {
> the parameter givenCtypeId is null, so Buckminster looks for the possible types. It finds two types for my component:
> our own EAR-Type and osgi.bundle.
> further down in LocalResolver#fromPath the resolution is created for the type
> BOMNode node = ctype.getResolution(pm, MonitorUtils.subMonitor(monitor, 100));
> this works for the EAR-Type (our ResolutionBuilder is called), but it fails for the osgi.bundle with a
> MissingAttributeException.
> how can i fix this problem ?
Sounds like a bug in Buckminster. It shouldn't fail unless all possible types fail. Please report this as a bug and I'll
see to that it gets fixed.
- thomas
FUDForum. Page generated in 0.02732 seconds
