Home » Archived » AM3 » Error while compiling AM3 plugin EMFModelFactory.java
Error while compiling AM3 plugin EMFModelFactory.java [message #768088] Mon, 19 December 2011 10:00 Go to next message
Sangeeta Tripathy is currently offline Sangeeta Tripathy
I get the following error when I compile the source code of plugin EMFModelFactory.java in the package org.eclipse.am3.moscript.core.emf.
Error: "The method setResource(Resource) from type EMFModel is not visible"
at the code: model.setResource(builtin)
The class extends org.eclipse.m2m.atl.core.emf.EMFReferenceModel.
I am not able to get past this error, please help me out.
Thanks.
[Updated on: Mon, 19 December 2011 10:04]
Report message to a moderator
Re: Error while compiling AM3 plugin EMFModelFactory.java [message #768094 is a reply to message #768088] Mon, 19 December 2011 10:17 Go to previous messageGo to next message
Wolfgang Kling is currently offline Wolfgang Kling
Hello Sangee, if you are planning to use MoScript with AM3 you have to follow the instructions in this link h t t p ://wiki.eclipse.org/MoScript if not, just do not checkout the packages containing the word "moscript" in their name.
Re: Error while compiling AM3 plugin EMFModelFactory.java [message #768098 is a reply to message #768088] Mon, 19 December 2011 10:18 Go to previous messageGo to next message
Hello Sangee, if you are planning to use MoScript with AM3 you have to follow the instructions in this link wiki.eclipse.org/MoScript
If not, just do not checkout the packages containing the word "moscript" in their name.
Re: Error while compiling AM3 plugin EMFModelFactory.java [message #768246 is a reply to message #768098] Mon, 19 December 2011 15:08 Go to previous messageGo to next message
Wolfgang,
Thanks.
I have successfully compiled all the source code for AM3 plugins, (excluding MOScript). But when I install the plugins and restart Eclipse in AM3 perspective, I do not see the Injection option when I right-click on an XML file. I have installed AM3 mainly for XML injection and extraction. I have Eclipse Helios RC3 with ATL. How do I get this to work?
-Sangeeta
Re: Error while compiling AM3 plugin EMFModelFactory.java [message #768541 is a reply to message #768246] Tue, 20 December 2011 05:35 Go to previous messageGo to next message
Guillaume Doux is currently offline Guillaume Doux
Member
As I told you in a previous thread, you could have installed only the plugin containing the XML projector (org.eclipse.m2m.atl.projectors.xml) because it depends only of ATL. But if you have installed the whole AM3 plugins it's ok.
It's not integrated with the GUI, you should launch it using the ATL ANT tasks, which is the standard way to work with injectors in ATL. Here is the link to the documentation:
http://wiki.eclipse.org/ATL/User_Guide_-_The_ATL_Tools#Task_atl.loadModel
You should write something like that for your load model task:
  <atl.loadModel modelHandler="EMF" name="XML" metamodel="MOF" path="metamodels/XML.ecore" />
  <atl.loadModel name="myXML" metamodel="XML" path="inputs/MySample.xml">
     <injector name="XML" />
  </atl.loadModel>
Guillaume
PS: The complete discussion we add on this topic could have been done in only one forum thread. It's easier to remember the story of what peoples want to do. Moreover it's not because you don't have an answer during the afternoon that you need to open a second topic for the same thing.
Re: Error while compiling AM3 plugin EMFModelFactory.java [message #768929 is a reply to message #768541] Tue, 20 December 2011 23:27 Go to previous messageGo to next message
Thanks, and sorry for the multiple threads.
As I understand, I require only XML projector plugin to use XML injection/extraction. Besides Ant, can I also invoke using a Java program?
Re: Error while compiling AM3 plugin EMFModelFactory.java [message #769045 is a reply to message #768929] Wed, 21 December 2011 05:01 Go to previous messageGo to next message
Member
Yes, that's it.
Launching ATL with a Java program is possible, you should look at the developer documentation:
http://wiki.eclipse.org/ATL/Developer_Guide
If you have questions about this, I suppose it's better to ask them directly on the m2m forum with the ATL tag (http://www.eclipse.org/forums/index.php/f/23/)
Guillaume
Re: Error while compiling AM3 plugin EMFModelFactory.java [message #773793 is a reply to message #769045] Mon, 02 January 2012 09:56 Go to previous messageGo to next message
I am invoking the XML injection (XMLInjector) using Java code to convert an XML file to XMI. It seems to be working without errors, but how can I access(read) the injected model (XMI)?
I would need to read it in order to write the ATL rules for transformation.
Please guide me.
Re: Error while compiling AM3 plugin EMFModelFactory.java [message #774116 is a reply to message #773793] Tue, 03 January 2012 04:47 Go to previous message
Member
The XML injection create a model conform to this XML metamodel:
http://www.emn.fr/z-info/atlanmod/index.php/Ecore#XML_1.1
Once you have the XML model you should translate it into your metamodel using a standard ATL transformation.
Guillaume
Previous Topic:Problem running new AM3 plugins
Next Topic:example ATL Transformation don't work
Current Time: Thu May 23 00:21:26 EDT 2013
Powered by FUDForum. Page generated in 0.05904 seconds
