Home » Eclipse Projects » Virgo » Virgo Heap Dump
Virgo Heap Dump [message #767482] Sat, 17 December 2011 23:38 Go to next message
karthik elavan is currently offline karthik elavan
Member
Hello Friends,
I had been using virgo 2.1.0,2.1.1,3.0.0,3.0.2 version it's working fine my application. But i have to some doubt sharing to all, deployed the WAR file multiple time(i mean more then 3 times) the server response message from console as well as LOG file out come to HEAP DUMP Exception & Hung the server. How to solve this problem, If i want increase memory size for virgo server or java side (jvm arguments or server argument) Please help me.
Re: Virgo Heap Dump [message #767902 is a reply to message #767482] Mon, 19 December 2011 02:24 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
Can you please post the logs that are produced with the heap dump?
Re: Virgo Heap Dump [message #767977 is a reply to message #767902] Mon, 19 December 2011 04:59 Go to previous message
Glyn Normington is currently offline Glyn Normington
When running Virgo using the startup scripts, you can specify JVM options such as -Xmx in the JAVA_OPTS environment variable.
Previous Topic:Deploy war file
Next Topic:how to export PAR/bundle with my own manifest
Current Time: Thu May 23 18:02:14 EDT 2013
Powered by FUDForum. Page generated in 0.01861 seconds
