Home » Eclipse Projects » Gemini » Using blueprint in PDE
Using blueprint in PDE [message #767048] Fri, 16 December 2011 18:17 Go to next message
couzteau  is currently offline couzteau
I'm new to PDE and gemini, but I'm very familiar with spring framework.
I was trying to set install gemini blueprint into eclipse for plugin developement.
But I'm a bit lost to where and how to start.
first where do I get the implementation, I have found this download page with a 2.0 release:
build.eclipse.org/rt/virgo/maven/bundles/release/org/eclipse/gemini/web/
I also downloaded the latest release but that's version 1.0 from the apparently official Gemini Blueprint site
www.eclipse.org/gemini/blueprint/download/
Which one should I use?
Thanks for help.
Jacques
PS: I was forced to remove the protocol from the links, because I'm not allowed to post links as a newbie on this forum to the links because I need to
Re: Using blueprint in PDE [message #767960 is a reply to message #767048] Mon, 19 December 2011 04:36 Go to previous message
Glyn Normington is currently offline Glyn Normington
build.eclipse.org/rt/virgo/maven/bundles/release/org/eclipse/gemini/web/ contains the Gemini Web bundles which you shouldn't confused with Gemini Blueprint at www.eclipse.org/gemini/blueprint/download/.
Previous Topic:During createEntityManagerFactory "Malformed (null) URL" Hides True Exception
Next Topic:Spring dm, eclipselink and weaving hell
Current Time: Sat May 18 07:16:07 EDT 2013
Powered by FUDForum. Page generated in 0.01560 seconds
