| org.w3c.dom.svg broken in Eclipse 3.7? [message #766391] |
Thu, 15 December 2011 12:39  |
Thorsten Meinl Messages: 83 Registered: July 2009 |
Member |
Hi all,
We are using the org.w3c.dom.svg plug-in from Orbit in our project. This
requires org.w3c.dom.smil in version 1.0.0. This works perfectly fine in
Eclipse 3.6. Now, if I use the very same plug-ins in Eclipse 3.7 it
complains (either during validation in the "Plug-ins" tab of a run
configuration or during startup) that it cannot resolve org.w3c.dom.svg
because the dependecy org.w3c.dom.smil_0.0.0 is missin. But it is
actually there. What I find a bit suspicious is that the complaint does
not contain the version range defined in the MANIFEST.MF but simply
0.0.0. Since all that changed is the Eclipse version, it seem that
Eclipse 3.7 has broken something. Does anyone have an idea?
It is very easy to reproduce: just create a new launch configuration and
select only the org.w3c.dom.svg and org.w3c.dom.smil Plug-ins. Even if
you all all required plug-ins validation still fails. On the source code
level, i.e. when using them in projects everything is fine.
Thorsten
| Re: org.w3c.dom.svg broken in Eclipse 3.7? [message #767036 is a reply to message #766653] |
Fri, 16 December 2011 17:30  |
David Williams Messages: 176 Registered: July 2009 |
On 12/16/2011 02:46 AM, Thorsten Meinl wrote:
> Am 15.12.2011 22:39, schrieb Thorsten Meinl:
>> Yes, this seems to fix it. I'm not sure where the old version came from
>> in the first place, but explicitly requiring while creating the target
>> platform the new version fixes everything. Thanks for the hint!
> Ah, now I know. Birt 2.6.2 brings the old version with it. Bummer...
They should have an update for "Indigo" (3.7 platform). If you can
upgrade to that level. You should have
http://download.eclipse.org/releases/indigo/
built-in to your 3.7 environment. Of course, then you might run into other
issues or incompatibilities (updating directly from 3.6 stuff to 3.7
stuff from the repo should work in theory, but its usually discouraged,
since no one tests it.
Or, you could try fresh all-in-one install for
Eclipse IDE for Java and Report Developers
www.eclipse.org/downloads
Good luck,
FUDForum. Page generated in 0.01764 seconds
