Home » Eclipse Projects » Virgo » NamespaceHandler
NamespaceHandler [message #766353] Thu, 15 December 2011 10:50 Go to next message
Frederic Boucher is currently offline Frederic Boucher
I got some troubles with the NamespaceHandler management in spring-dm and virgo. I explained my problem here: http ://www.eclipse.org/forums/index.php/t/265692/
When spring-dm refresh a spring bundle, it use a DelegateNamespaceHandlerResolver composed of:
- a "local NamespaceHandlerResolver" that use the ClassLoader of the bundle to find the spring.handlers file;
- a "OSGI service NamespaceHandlerResolver" that use an osgi service to find the NamespaceHandler;
In a first time, I thought that my issue come from the "OSGI service NamespaceHandlerResolver" (http ://www.eclipse.org/forums/index.php/t/265692/).
But I found this code in the class MetaInfResourceClassLoaderDelegateHook from the Virgo code source:
    private boolean isDelegatedResolverCall() {
        StackTraceElement[] stackTrace = Thread.currentThread().getStackTrace();
        return isSpringDmDelegatedResolverCall(stackTrace) || isBlueprintDelegatedResolverCall(stackTrace);
    private boolean isSpringDmDelegatedResolverCall(StackTraceElement[] stackTrace) {
        return isDelegatedResolverCall(stackTrace, SPRINGDM_DELEGATED_NAMESPACE_HANDLER_RESOLVER_CLASS_NAME, SPRINGDM_DELEGATED_ENTITY_RESOLVER_CLASS_NAME);
    private boolean isBlueprintDelegatedResolverCall(StackTraceElement[] stackTrace) {
        return isDelegatedResolverCall(stackTrace, BLUEPRINT_DELEGATED_NAMESPACE_HANDLER_RESOLVER_CLASS_NAME, BLUEPRINT_DELEGATED_ENTITY_RESOLVER_CLASS_NAME);
It seems that this code is here to avoid to use the "local NamespaceHandlerResolver" when loading the bean definitions using Spring-Dm but I don't understand why ?
regards,
Frederic
Re: NamespaceHandler [message #766701 is a reply to message #766353] Fri, 16 December 2011 04:30 Go to previous message
Glyn Normington is currently offline Glyn Normington
The purpose of MetaInfResourceClassLoaderDelegateHook is to propagate an attempt to get resource(s) from META-INF to the principle bundle's dependencies, but this is not done if the request is being driven through Spring DM's DelgatedNamespaceHandlerResolver as it would not be appropriate to get namespace handlers directly from a bundle's dependencies. This logic should not affect the behaviour of the local namespace handler resolver as that only depends on looking up resources in a bundle's own META-INF.
Previous Topic:faild to build org.eclipse.virgo.kernel.userregion
Next Topic:Deploy war file
Current Time: Sat May 25 05:35:08 EDT 2013
Powered by FUDForum. Page generated in 0.07864 seconds
