| Part of Selection table binding problem [message #766137] |
Thu, 15 December 2011 04:11  |
Mark . Messages: 10 Registered: July 2010 |
Junior Member |
Hi all,
I have set up two tables that are linked much the same as the phone book windowsbuilder example.
However, in my program when I click the source table the target table is populated as expected...the first time. If I select another row in the source table the rows I expect to see in the target table are appended. This means the table grows indefinitely! If I selected the same source row twice nothing happens, i.e., it doesn't append the same results to the target table again. It only happens when I selected a different row. Note, I can go back to the previous source row and it will append again.
I am restricted to SDK 3.5.2 due to the target OS being SLES9 and having out-dated GTK libs. This means the databinding libs are 1.2.0 and 1.3.1. Not sure if this is the root of the problem.
On a side note, I also have to update the table manual when the model is changed externally (the table actually has no ability to change the model, it's for display only). I do this successfully in other software that uses newer eclipse SDK's (3.6 upwards) so I guessed that was the databinding libs i'm restricted to on SLES9.
I've not put any code in as I think it may be a version problem or something that an expert will recognise straight away. If not, I can post more later.
Thanks!
| Re: Part of Selection table binding problem [message #766322 is a reply to message #766314] |
Thu, 15 December 2011 09:55  |
Eric Clayberg Messages: 737 Registered: July 2009 Location: Boston, MA |
If there is a problem with the generated binding code, we would be happy to look at it. None of the WB committers are Eclipse DB experts, however, and none of us have more than minimal experience using it. To the extent that their are DB experts in the Eclipse community, you would find them in the JFace forum (which specifically lists the DB framework as one of its main topics).
Again, I would suggest posting a complete (and ideally minimal) test case.
FUDForum. Page generated in 0.01652 seconds
