Home » Eclipse Projects » BIRT » xls output and wrong file format on Excel 2007
xls output and wrong file format on Excel 2007 [message #764481] Mon, 12 December 2011 04:21 Go to next message
Nicklas Karlsson is currently offline Nicklas Karlsson
I read some topics on the "The file you are trying to open is of different format..." and I tried to make a filename-generator-impl that would produce .xlsx files but that didn't help either. Is there any way to control the response content-type headers?
Re: xls output and wrong file format on Excel 2007 [message #764699 is a reply to message #764481] Mon, 12 December 2011 12:39 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Nicklas,
The content type is set in the plugin.xml for the emitter and the
extension used is set in the viewer.properties for the deployed viewer:
# [EXTENSION SETTING]
viewer.extension.html=html
viewer.extension.pdf=pdf
viewer.extension.postscript=ps
viewer.extension.doc=doc
viewer.extension.xls=xls
viewer.extension.ppt=ppt
viewer.extension.ods=ods
viewer.extension.odt=odt
viewer.extension.odp=odp
You could change both but I do not think it will work because the xls
emitter does not generate xlsx files.
Jason
On 12/12/2011 4:21 AM, Nicklas Karlsson wrote:
Jason Weathersby
BIRT Exchange
Re: xls output and wrong file format on Excel 2007 [message #764946 is a reply to message #764699] Tue, 13 December 2011 01:26 Go to previous messageGo to next message
It doesn't? Strange, wonder why Excel is complaining then if the xls produced is an xls?
Thanks, I'll see what the xml tuning produces...
Re: xls output and wrong file format on Excel 2007 [message #765237 is a reply to message #764946] Tue, 13 December 2011 12:19 Go to previous message
Nicklas,
It is producing a 2003 version of the xml format for excel.
Have a look at this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=267988
You could also look at the tribix emitters or this entry
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1421-native-excel-emitter-plugin-for-birt/
Jason
> produced is an xls?
Jason Weathersby
BIRT Exchange
Previous Topic:Missing hyperlink when report loaded from hyperlink
Next Topic:Unable to print image on Excel output in BIRT 3.7.1
Current Time: Tue May 21 22:06:31 EDT 2013
Powered by FUDForum. Page generated in 0.01722 seconds
