Home » Eclipse Projects » EGL Development Tools » Lesson 4 - bug in the start function
Lesson 4 - bug in the start function [message #764973] Tue, 13 December 2011 02:57 Go to next message
isterakas is currently offline isterakas
When i try add the prototype data in the start function, in Design view the following message appears:
Could not render UI
Αναμένεται αντικείμενο
[CRRUI2094E] Here are the EGL function calls leading to this error:
PaymentFileMaintenance.start() [native JavaScript]
PaymentClient/handlers/PaymentFileMaintenance.js?contextKey=23:267
[CRRUI2095E] Could not find the EGL function calls leading to this error
Re: Lesson 4 - bug in the start function [message #764977 is a reply to message #764973] Tue, 13 December 2011 03:07 Go to previous messageGo to next message
fahua jin is currently offline fahua jin
Member
Not sure for prototype data? Could you please check if you have the same problem described in http://www.eclipse.org/forums/index.php/t/264546/?
If it's not the same problem, could you please upload the 3 projects in your workspace? Thank you!
Rocky
Re: Lesson 4 - bug in the start function [message #764986 is a reply to message #764977] Tue, 13 December 2011 03:21 Go to previous messageGo to next message
It was the same problem. When i checked (and) the javascript generator of the PaymentService project the problem solved.
Thanks a lot.
Re: Lesson 4 - bug in the start function [message #765092 is a reply to message #764986] Tue, 13 December 2011 07:00 Go to previous message
Member
The PAYMENT record should be created in the PaymentShared project, and since the PaymentShared already configured with Java & JavaScript generator, it's not necessary to modify the generator setting of PaymentService project.
Previous Topic:Tutorial issues or config bugs
Next Topic:Food for thought -- need a way to deploy JS only apps
Current Time: Tue May 21 22:07:22 EDT 2013
Powered by FUDForum. Page generated in 0.01596 seconds
