Home » Modeling » Textual Concrete Syntax (TCS) » How can I generate MM-TCS.ecore?
How can I generate MM-TCS.ecore? [message #765031] Tue, 13 December 2011 04:46
pere b is currently offline pere b
I want to do a M2M transformation and then a M2T transformation in a java program. I'm following the example provided by Milan Milanovic. It seems I would need a file called MM-TCS.ecore but I only have MM.tcs. How can I generate MM-TCS.ecore?
Thank you for your help.
Previous Topic:How to install TCS
Next Topic:TCS status
Current Time: Tue May 28 19:46:16 EDT 2013
Powered by FUDForum. Page generated in 0.01380 seconds
