Home » Modeling » XSD » Load EMF from xml stream(Problems loading from stream)
Load EMF from xml stream [message #765029] Tue, 13 December 2011 04:42
Frank Missing name is currently offline Frank Missing name
I have a question regarding loading an EMF model from a stream.
I have two functions:
public static EObject load(File file) throws IOException {
    ResourceSet resSet = new ResourceSetImpl();
    Map<String, Object> loadMap = configure(resSet);
    URI fileUri = URI.createFileURI(file.getAbsolutePath());
    Resource res = resSet.getResource(fileUri, true);
    res.load(loadMap);
    return res.getContents().get(0);
private static Map<String, Object> configure(ResourceSet resSet) throws IOException {
    Map<String, Object> parserFeatures = new HashMap<String, Object>();
    Map<String, Object> parserProperties = new LinkedHashMap<String, Object>();
    Map<String, Object> loadMap = new HashMap<String, Object>();
    loadMap.put(XMLResource.OPTION_USE_PARSER_POOL, new XMLParserPoolImpl());
    loadMap.put(XMLResource.OPTION_EXTENDED_META_DATA, ExtendedMetaData.INSTANCE);
    parserFeatures.put("htp://xml.org/sax/features/validation", Boolean.TRUE);
    URL find = FileLocator.find(Activator.getContext().getBundle(), new Path("model/pack.xsd"), null);
    parserProperties.put("htp://java.sun.com/xml/jaxp/properties/schemaLanguage", "htp://www.w3.org/2001/XMLSchema");
    InputStream schemaStream = find.openStream();
    parserProperties.put("htp://java.sun.com/xml/jaxp/properties/schemaSource", schemaStream);
    resSet.getLoadOptions().put(XMLResource.OPTION_USE_PARSER_POOL, new XMLParserPoolImpl());
    resSet.getLoadOptions().put(XMLResource.OPTION_PARSER_FEATURES, parserFeatures);
    resSet.getLoadOptions().put(XMLResource.OPTION_PARSER_PROPERTIES, parserProperties);
    resSet.getPackageRegistry().put(PackPackage.eINSTANCE.getNsURI(), PackPackage.eINSTANCE);
    resSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("pack", new PackResourceFactoryImpl());
    return loadMap;
which are working fine.
When it comes to load the model from a stream, I get into trouble ...
public static EObject load(InputStream inStream) throws IOException {
     Resource res = resSet.createResource(URI.createURI("htp:///My.pack"), "pack");
     res.load(inStream, loadMap);
I get this error:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null' not found. (htp:///My.pack, 2, 7)
If I remove this line:
it works with streams also. However, the documentation says to use this setting for models created from a schema. So what is going wrong? Any idea?
Thanks in advance
Frank
(I had to use htp instead of http since I am not allowed to post links yet ...)
Previous Topic:Serialize XSD Object
Next Topic:choice between groups in xsd
Current Time: Fri May 24 14:09:14 EDT 2013
Powered by FUDForum. Page generated in 0.06994 seconds
