| AMP contains non IP-approved content?! [message #764147] |
Sun, 11 December 2011 08:52  |
Werner Keil Messages: 1068 Registered: July 2009 |
Just installed the Modeling distro of Indigo SR1 after DemoCamp attendees
including Eike Stepper suggested, we might follow up on earlier discussed
UOMo/UCUM integration with EMF. When looking up Modeling Components, the
discovery tool states, AMP contains non IP-approved content.
How did you even get it into the discovery then?!;-|
Werner
| Re: AMP contains non IP-approved content?! [message #764732 is a reply to message #764147] |
Mon, 12 December 2011 14:05  |
Miles Parker Messages: 1266 Registered: July 2009 |
IIRC, this was actually one of the original reasons for the Discovery setup. Xtext also had such non Eclipse-IP pieces for their ANTLR integration. This is essentially the same approach that SVN uses for their non-Eclipse connectors. But we went through it pretty carefully to make sure that the notifications were there.
You can also just get the features from the AMP feature site. The only non-Eclipse IP stuff is the support for 3D graphics which is completely an optional thing.
FUDForum. Page generated in 0.24150 seconds
