| Re: Code Generation with Acceleo (Autosar XSD -> C Code) [message #764623 is a reply to message #762554] |
Mon, 12 December 2011 09:51  |
Laurent Goubet Messages: 1548 Registered: July 2009 |
Please use the M2T newsgroup for questions regarding Acceleo, the Acceleo team does not monitor this forum (I only stumbled upon this question by chance).
The tutorials we provide are for the basic use cases, using an XSD schema is slightly more complicated than that. However, we do support it as long as you have set your environment to be able to load autosar models. The easiest way for this would be to look into Artop and use their environment. Other than that, you will have to take the long way 'round and create the metamodel corresponding to the Autosar XSD. Please take a look at the different EMF to XSD tutorials around (Never did it myself, but this one seem like a good start).
Once you have the metamodel, you can use Acceleo with it as you would with any other metamodel.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.01528 seconds
