Home » Eclipse Projects » Virgo » userregionfactory failed to start
| userregionfactory failed to start [message #760237] |
Thu, 01 December 2011 11:45  |
malik Messages: 13 Registered: November 2011 |
Junior Member |
when virgo starts loading, after a couple of seconds it throws this exception:
org.osgi.framework.BundleException: Bundle org.eclipse.virgo.kernel.userregionfactory 3.0.1.RELEASE failed to start
but this happens only when i run virgo with -Xmx512m
when virgo runs with -Xmx1500m it runs just fine!
now I saw in the stack trace this line:
"Caused by: java.util.concurrent.TimeoutException"
so I think it's taking too long for virgo to load (because it has only -Xmx512m)
so if this is the problem is there a way to increase the loading time timeout?
and if not, why is this happening?
here the full stack trace:
2011-12-01 17:27:57.569 INFO [main] o.e.virgo.medic.eventlog.default - Dump 'serviceability/dump/2011-12-01-17-27-680' generated
2011-12-01 17:27:57.571 ERROR [main] System.err - org.osgi.framework.BundleException: Bundle org.eclipse.virgo.kernel.userregionfactory 3.0.1.RELEASE failed to start.
2011-12-01 17:27:57.572 ERROR [main] System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.installAndStartBundles(FrameworkBuilder.java:189)
2011-12-01 17:27:57.572 ERROR [main] System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.start(FrameworkBuilder.java:159)
2011-12-01 17:27:57.572 ERROR [main] System.err - at org.eclipse.virgo.osgi.launcher.Launcher.main(Launcher.java:54)
2011-12-01 17:27:57.573 ERROR [main] System.err - Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregionfactory.Activator.start() of bundle org.eclipse.virgo.kernel.userregionfactory.
2011-12-01 17:27:57.573 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
2011-12-01 17:27:57.573 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
2011-12-01 17:27:57.574 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
2011-12-01 17:27:57.575 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
2011-12-01 17:27:57.575 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
2011-12-01 17:27:57.574 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent RESOLVED
2011-12-01 17:27:57.576 ERROR [main] System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.installAndStartBundles(FrameworkBuilder.java:187)
2011-12-01 17:27:57.582 ERROR [main] System.err - ... 2 more
2011-12-01 17:27:57.583 ERROR [main] System.err - Caused by: org.osgi.framework.BundleException: Failed to start bundle org.eclipse.virgo.kernel.userregion 3.0.1.RELEASE
2011-12-01 17:27:57.583 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.initialiseUserRegionBundles(Activator.java:349)
2011-12-01 17:27:57.583 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.createUserRegion(Activator.java:178)
2011-12-01 17:27:57.584 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.start(Activator.java:133)
2011-12-01 17:27:57.584 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
2011-12-01 17:27:57.584 ERROR [main] System.err - at java.security.AccessController.doPrivileged(Native Method)
2011-12-01 17:27:57.585 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
2011-12-01 17:27:57.585 ERROR [main] System.err - ... 7 more
2011-12-01 17:27:57.585 ERROR [main] System.err - Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregion.internal.Activator.start() of bundle org.eclipse.virgo.kernel.userregion.
2011-12-01 17:27:57.582 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 81, ServiceEvent REGISTERED
2011-12-01 17:27:57.586 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 82, ServiceEvent REGISTERED
2011-12-01 17:27:57.587 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent STARTED
2011-12-01 17:27:57.587 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregion_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:27:57.587 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregionfactory_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:27:57.577 INFO [kernel-dm-3] o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [bundleentry://38.fwk12213211/META-INF/spring/osgi-context.xml]
2011-12-01 17:27:57.622 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
2011-12-01 17:27:57.628 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
2011-12-01 17:27:57.628 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
2011-12-01 17:27:57.629 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
2011-12-01 17:27:57.629 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
2011-12-01 17:27:57.629 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.initialiseUserRegionBundles(Activator.java:345)
2011-12-01 17:27:57.629 ERROR [main] System.err - ... 12 more
2011-12-01 17:27:57.630 ERROR [main] System.err - Caused by: java.util.concurrent.TimeoutException: org.eclipse.virgo.repository.Repository
2011-12-01 17:27:57.636 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregion.internal.Activator.getPotentiallyDelayedService(Activator.java:352)
2011-12-01 17:27:57.637 ERROR [main] System.err - at org.eclipse.virgo.kernel.userregion.internal.Activator.start(Activator.java:101)
2011-12-01 17:27:57.637 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
2011-12-01 17:27:57.637 ERROR [main] System.err - at java.security.AccessController.doPrivileged(Native Method)
2011-12-01 17:27:57.649 INFO [kernel-dm-1] o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [bundleentry://35.fwk12213211/META-INF/spring/io-context.xml]
2011-12-01 17:27:57.638 ERROR [main] System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
2011-12-01 17:27:57.683 INFO [kernel-dm-4] o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [bundleentry://39.fwk12213211/META-INF/spring/internal-osgi-context.xml]
2011-12-01 17:27:57.655 ERROR [main] System.err - ... 17 more
2011-12-01 17:27:57.688 INFO [kernel-dm-2] o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL [bundleentry://36.fwk12213211/META-INF/spring/osgi-context.xml]
thanks in advance.
| Re: userregionfactory failed to start [message #760686 is a reply to message #760628] |
Sun, 04 December 2011 03:51   |
Junior Member |
hi agine,
I add the startup log and the the userregion.properties file after moifay.
startup log:
2011-12-01 17:27:06.036 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.medic.core_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.048 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.osgi_3.0.1.RELEASE, Service 51, ServiceEvent REGISTERED
2011-12-01 17:27:06.049 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.osgi_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.062 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.event_1.2.100.v20110110, Service 52, ServiceEvent REGISTERED
2011-12-01 17:27:06.070 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.event_1.2.100.v20110110, BundleEvent STARTED
2011-12-01 17:27:06.211 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.common_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.243 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.io_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.255 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.math_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.256 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.util.parser.manifest_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.256 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.commons.codec_1.3.0, BundleEvent STARTED
2011-12-01 17:27:06.256 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.commons.httpclient_3.1.0, BundleEvent STARTED
2011-12-01 17:27:06.369 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.repository_3.0.1.RELEASE, Service 53, ServiceEvent REGISTERED
2011-12-01 17:27:06.526 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.repository_3.0.1.RELEASE, Service 54, ServiceEvent REGISTERED
2011-12-01 17:27:06.553 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.repository_3.0.1.RELEASE, Service 55, ServiceEvent REGISTERED
2011-12-01 17:27:06.555 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.repository_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.555 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:06.556 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.agent.dm_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:07.942 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 56, ServiceEvent REGISTERED
2011-12-01 17:27:07.945 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 57, ServiceEvent REGISTERED
2011-12-01 17:27:08.823 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from OSGi resource
2011-12-01 17:27:12.147 INFO o.s.b.f.s.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@f63055: defining beans ; root of factory hierarchy
2011-12-01 17:27:12.695 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 58, ServiceEvent REGISTERED
2011-12-01 17:27:13.243 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, BundleEvent STARTED
2011-12-01 17:27:13.337 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:13.713 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:13.948 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.ds_1.3.0.v20110124-0830, Service 59, ServiceEvent REGISTERED
2011-12-01 17:27:14.154 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:14.481 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.event_1.2.100.v20110110, Service 60, ServiceEvent REGISTERED
2011-12-01 17:27:15.501 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 61, ServiceEvent REGISTERED
2011-12-01 17:27:15.558 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 62, ServiceEvent REGISTERED
2011-12-01 17:27:15.756 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 63, ServiceEvent REGISTERED
2011-12-01 17:27:15.762 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:15.792 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 64, ServiceEvent REGISTERED
2011-12-01 17:27:15.793 INFO o.s.s.c.ThreadPoolTaskExecutor - Initializing ExecutorService
2011-12-01 17:27:15.867 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 65, ServiceEvent REGISTERED
2011-12-01 17:27:15.899 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 66, ServiceEvent REGISTERED
2011-12-01 17:27:16.098 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 67, ServiceEvent REGISTERED
2011-12-01 17:27:16.226 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 68, ServiceEvent REGISTERED
2011-12-01 17:27:16.257 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 69, ServiceEvent REGISTERED
2011-12-01 17:27:16.487 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:16.711 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 70, ServiceEvent REGISTERED
2011-12-01 17:27:16.770 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 71, ServiceEvent REGISTERED
2011-12-01 17:27:16.822 INFO o.e.virgo.medic.eventlog.default - Kernel starting.
2011-12-01 17:27:16.874 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 72, ServiceEvent REGISTERED
2011-12-01 17:27:16.882 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 72, ServiceEvent UNREGISTERING
2011-12-01 17:27:16.905 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.core_3.0.1.RELEASE, Service 73, ServiceEvent REGISTERED
2011-12-01 17:27:17.014 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'scopeFactory': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:27:17.058 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.234 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.agent.dm_3.0.1.RELEASE, Service 74, ServiceEvent REGISTERED
2011-12-01 17:27:17.309 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.agent.dm_3.0.1.RELEASE, Service 75, ServiceEvent REGISTERED
2011-12-01 17:27:17.346 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'kernelConfig': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:27:24.405 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.657 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.592 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.564 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:17.361 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.agent.dm_3.0.1.RELEASE, Service 77, ServiceEvent REGISTERED
2011-12-01 17:27:24.455 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.ds_1.3.0.v20110124-0830, Service 76, ServiceEvent REGISTERED
2011-12-01 17:27:24.492 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.ds_1.3.0.v20110124-0830, Service 78, ServiceEvent REGISTERED
2011-12-01 17:27:24.494 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.ds_1.3.0.v20110124-0830, BundleEvent STARTED
2011-12-01 17:27:24.510 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, Service 79, ServiceEvent REGISTERED
2011-12-01 17:27:24.563 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, Service 80, ServiceEvent REGISTERED
2011-12-01 17:27:24.565 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, BundleEvent STARTED
2011-12-01 17:27:24.566 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.artifact_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.566 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.services_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.566 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.model_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.567 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.shell_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.567 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.osgi_3.0.1.RELEASE, BundleEvent STARTED
2011-12-01 17:27:24.567 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent INSTALLED
2011-12-01 17:27:24.568 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregion_3.0.1.RELEASE, BundleEvent INSTALLED
2011-12-01 17:27:24.568 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.osgicommand_3.0.1.RELEASE, BundleEvent INSTALLED
2011-12-01 17:27:24.568 INFO org.osgi.service.log.LogService - Bundle org.eclipse.osgi.services_3.3.0.v20110110, BundleEvent INSTALLED
2011-12-01 17:27:24.569 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.mina.core_2.0.2, BundleEvent INSTALLED
2011-12-01 17:27:24.569 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.command_0.8.0.v201105062003, BundleEvent INSTALLED
2011-12-01 17:27:24.570 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.runtime_0.8.0.v201105062003, BundleEvent INSTALLED
2011-12-01 17:27:24.570 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.shell_0.8.0.v201107131313, BundleEvent INSTALLED
2011-12-01 17:27:24.603 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.console.supportability_1.0.0.201108021516, BundleEvent INSTALLED
2011-12-01 17:27:24.604 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.sshd.core_0.5.0, BundleEvent INSTALLED
2011-12-01 17:27:24.604 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.runtime_0.8.0.v201105062003, BundleEvent RESOLVED
2011-12-01 17:27:24.605 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.shell_0.8.0.v201107131313, BundleEvent RESOLVED
2011-12-01 17:27:24.605 INFO org.osgi.service.log.LogService - Bundle org.apache.felix.gogo.command_0.8.0.v201105062003, BundleEvent RESOLVED
2011-12-01 17:27:24.606 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.mina.core_2.0.2, BundleEvent RESOLVED
2011-12-01 17:27:24.606 INFO org.osgi.service.log.LogService - Bundle com.springsource.org.apache.sshd.core_0.5.0, BundleEvent RESOLVED
2011-12-01 17:27:24.619 INFO org.osgi.service.log.LogService - Bundle org.eclipse.osgi.services_3.3.0.v20110110, BundleEvent RESOLVED
2011-12-01 17:27:24.620 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.console.supportability_1.0.0.201108021516, BundleEvent RESOLVED
2011-12-01 17:27:24.620 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.osgicommand_3.0.1.RELEASE, BundleEvent RESOLVED
2011-12-01 17:27:24.620 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregion_3.0.1.RELEASE, BundleEvent RESOLVED
2011-12-01 17:27:57.569 INFO o.e.virgo.medic.eventlog.default - Dump 'serviceability/dump/2011-12-01-17-27-680' generated
2011-12-01 17:27:57.571 ERROR System.err - org.osgi.framework.BundleException: Bundle org.eclipse.virgo.kernel.userregionfactory 3.0.1.RELEASE failed to start.
2011-12-01 17:27:57.572 ERROR System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.installAndStartBundles(FrameworkBuilder.java:189)
2011-12-01 17:27:57.572 ERROR System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.start(FrameworkBuilder.java:159)
2011-12-01 17:27:57.572 ERROR System.err - at org.eclipse.virgo.osgi.launcher.Launcher.main(Launcher.java:54)
2011-12-01 17:27:57.573 ERROR System.err - Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregionfactory.Activator.start() of bundle org.eclipse.virgo.kernel.userregionfactory.
2011-12-01 17:27:57.573 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
2011-12-01 17:27:57.573 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
2011-12-01 17:27:57.574 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
2011-12-01 17:27:57.575 ERROR System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
2011-12-01 17:27:57.575 ERROR System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
2011-12-01 17:27:57.574 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent RESOLVED
2011-12-01 17:27:57.576 ERROR System.err - at org.eclipse.virgo.osgi.launcher.FrameworkBuilder.installAndStartBundles(FrameworkBuilder.java:187)
2011-12-01 17:27:57.582 ERROR System.err - ... 2 more
2011-12-01 17:27:57.583 ERROR System.err - Caused by: org.osgi.framework.BundleException: Failed to start bundle org.eclipse.virgo.kernel.userregion 3.0.1.RELEASE
2011-12-01 17:27:57.583 ERROR System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.initialiseUserRegionBundles(Activator.java:349)
2011-12-01 17:27:57.583 ERROR System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.createUserRegion(Activator.java:178)
2011-12-01 17:27:57.584 ERROR System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.start(Activator.java:133)
2011-12-01 17:27:57.584 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
2011-12-01 17:27:57.584 ERROR System.err - at java.security.AccessController.doPrivileged(Native Method)
2011-12-01 17:27:57.585 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
2011-12-01 17:27:57.585 ERROR System.err - ... 7 more
2011-12-01 17:27:57.585 ERROR System.err - Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.virgo.kernel.userregion.internal.Activator.start() of bundle org.eclipse.virgo.kernel.userregion.
2011-12-01 17:27:57.582 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 81, ServiceEvent REGISTERED
2011-12-01 17:27:57.586 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 82, ServiceEvent REGISTERED
2011-12-01 17:27:57.587 INFO org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent STARTED
2011-12-01 17:27:57.587 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregion_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:27:57.587 INFO org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.userregionfactory_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:27:57.577 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:57.622 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
2011-12-01 17:27:57.628 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
2011-12-01 17:27:57.628 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
2011-12-01 17:27:57.629 ERROR System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
2011-12-01 17:27:57.629 ERROR System.err - at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
2011-12-01 17:27:57.629 ERROR System.err - at org.eclipse.virgo.kernel.userregionfactory.Activator.initialiseUserRegionBundles(Activator.java:345)
2011-12-01 17:27:57.629 ERROR System.err - ... 12 more
2011-12-01 17:27:57.630 ERROR System.err - Caused by: java.util.concurrent.TimeoutException: org.eclipse.virgo.repository.Repository
2011-12-01 17:27:57.636 ERROR System.err - at org.eclipse.virgo.kernel.userregion.internal.Activator.getPotentiallyDelayedService(Activator.java:352)
2011-12-01 17:27:57.637 ERROR System.err - at org.eclipse.virgo.kernel.userregion.internal.Activator.start(Activator.java:101)
2011-12-01 17:27:57.637 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
2011-12-01 17:27:57.637 ERROR System.err - at java.security.AccessController.doPrivileged(Native Method)
2011-12-01 17:27:57.649 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:57.638 ERROR System.err - at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
2011-12-01 17:27:57.683 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:57.655 ERROR System.err - ... 17 more
2011-12-01 17:27:57.688 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:27:57.821 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1347d33: defining beans ; root of factory hierarchy
2011-12-01 17:27:57.857 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:28:24.492 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'kernelConfig': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:28:24.492 INFO o.s.b.f.xml.XmlBeanDefinitionReader - Loading XML bean definitions from URL
2011-12-01 17:28:24.703 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'eventLogger': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:29:03.601 INFO o.s.b.f.s.DefaultListableBeanFactory - Overriding bean definition for bean 'kernelConfig': replacing [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null] with [Generic bean: class ; scope=; abstract=false; lazyInit=false; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null]
2011-12-01 17:29:03.889 ERROR o.e.virgo.medic.eventlog.default - Application context creation failure for bundle 'org.eclipse.virgo.kernel.deployer' version '3.0.1.RELEASE'.
org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'osgiFramework': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:209) ~
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288) ~
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190) ~
at org.springframework.osgi.extender.internal.dependencies.startup.MandatoryImporterDependencyFactory.getServiceDependencies(MandatoryImporterDependencyFactory.java:63) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.doFindDependencies(DependencyServiceManager.java:272) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.access$700(DependencyServiceManager.java:40) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager$1.run(DependencyServiceManager.java:213) ~
at org.springframework.osgi.extender.internal.util.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:124) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.findServiceDependencies(DependencyServiceManager.java:209) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecutor.java:239) ~
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecutor.java:169) ~
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:175) ~
at org.springframework.osgi.extender.internal.activator.ContextLoaderListener$2.run(ContextLoaderListener.java:716) ~
at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95) ~
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
2011-12-01 17:29:04.059 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1ebe8ec: defining beans ; root of factory hierarchy
2011-12-01 17:29:32.636 ERROR o.e.virgo.medic.eventlog.default - Kernel failed to start.
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) ~
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) ~
2011-12-01 17:29:04.431 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@24d517: defining beans ; root of factory hierarchy
2011-12-01 17:29:36.228 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@c71c00: defining beans ; root of factory hierarchy
2011-12-01 17:29:36.637 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@18ed284: defining beans ; root of factory hierarchy
2011-12-01 17:30:01.643 INFO o.e.virgo.medic.eventlog.default - Dump 'serviceability/dump/2011-12-01-17-29-637' generated
2011-12-01 17:30:01.665 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 56, ServiceEvent UNREGISTERING
2011-12-01 17:30:27.486 INFO o.e.virgo.medic.eventlog.default - Immediate shutdown initiated.
2011-12-01 17:30:27.458 INFO org.osgi.service.log.LogService - Bundle org.springframework.osgi.extender_1.2.1, Service 58, ServiceEvent UNREGISTERING
2011-12-01 17:30:27.488 INFO o.s.b.f.s.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@f63055: defining beans ; root of factory hierarchy
2011-12-01 17:30:54.181 INFO o.e.virgo.medic.eventlog.default - Shutdown initiated.
2011-12-01 17:30:54.347 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 82, ServiceEvent UNREGISTERING
2011-12-01 17:30:54.444 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, Service 81, ServiceEvent UNREGISTERING
2011-12-01 17:30:54.491 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.cm_1.0.300.v20101204, BundleEvent STOPPED
2011-12-01 17:30:54.521 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.osgi_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.535 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.shell_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.588 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.model_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.638 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.services_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.661 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.virgo.kernel.artifact_3.0.1.RELEASE, BundleEvent STOPPED
2011-12-01 17:30:54.662 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, Service 79, ServiceEvent UNREGISTERING
2011-12-01 17:30:54.724 INFO [org.eclipse.virgo.medic.log.osgi.OSGiLogServiceListener@1a80aea] org.osgi.service.log.LogService - Bundle org.eclipse.equinox.util_1.0.200.v20100503, Service 80, ServiceEvent UNREGISTERING
this is the userregion.properties file:
baseBundles = \
file:lib/kernel/org.eclipse.equinox.cm-1.0.300.v20101204.jar@start,\
file:lib/kernel/org.eclipse.virgo.kernel.userregion-3.0.1.RELEASE.jar@start,\
file:lib/kernel/org.eclipse.virgo.kernel.osgicommand-3.0.1.RELEASE.jar@start,\
file:lib/kernel/org.eclipse.osgi.services-3.3.0.v20110110.jar@start,\
file:lib/kernel/com.springsource.org.apache.mina.core-2.0.2.jar@start,\
file:lib/kernel/org.apache.felix.gogo.command-0.8.0.v201107131313.jar@start,\
file:lib/kernel/org.apache.felix.gogo.runtime-0.8.0.v201107131313.jar@start,\
file:lib/kernel/org.apache.felix.gogo.shell-0.8.0.v201107131313.jar@start,\
file:lib/org.eclipse.equinox.console.supportability-1.0.0.201108021516.jar@start,\
file:lib/kernel/com.springsource.org.apache.sshd.core-0.5.0.jar@start
bundleImports = org.eclipse.osgi;bundle-version="0"
packageImports =\
org.eclipse.virgo.kernel.artifact.*;version="0",\
org.eclipse.virgo.kernel.core;version="0",\
org.eclipse.virgo.kernel.deployer.core;version="0",\
org.eclipse.virgo.kernel.deployer.core.event;version="0",\
org.eclipse.virgo.kernel.deployer.config;version="0",\
org.eclipse.virgo.kernel.install.*;version="0",\
org.eclipse.virgo.kernel.osgi.*;version="0",\
org.eclipse.virgo.kernel.model;version="0",\
org.eclipse.virgo.kernel.model.management;version="0",\
org.eclipse.virgo.kernel.module;version="0",\
org.eclipse.virgo.kernel.serviceability;version="0",\
org.eclipse.virgo.kernel.serviceability.*;version="0",\
org.eclipse.virgo.kernel.services.work;version="0",\
org.eclipse.virgo.kernel.shell;version="0",\
org.eclipse.virgo.kernel.shell.*;version="0",\
org.eclipse.virgo.kernel.shim.*;version="0",\
org.eclipse.virgo.medic.*;version="0",\
org.eclipse.virgo.repository;version="0",\
org.eclipse.virgo.repository.*;version="0",\
org.eclipse.virgo.util.*;version="0",\
org.apache.commons.logging;version="[1.0.0,2.0.0)",\
org.apache.commons.logging.impl;version="[1.0.0,2.0.0)",\
org.aspectj.*;version="[1.6.5.RELEASE,2.0.0)",\
org.osgi.service.event;version="0",\
org.osgi.service.log;version="0",\
org.eclipse.equinox.region;version="1",\
ch.qos.logback.*;version="[0.9.24,1.0.0)",\
org.slf4j;version="[1.6.1,2)",\
org.slf4j.helpers;version="[1.6.1,2)",\
org.slf4j.spi;version="[1.6.1,2)"
serviceImports =\
org.eclipse.equinox.region.Region,\
org.eclipse.equinox.region.RegionDigraph,\
org.osgi.framework.hooks.resolver.ResolverHookFactory,\
org.eclipse.virgo.kernel.deployer.core.ApplicationDeployer,\
org.eclipse.virgo.kernel.deployer.core.DeployUriNormaliser,\
org.eclipse.virgo.kernel.install.artifact.ScopeServiceRepository,\
org.eclipse.virgo.kernel.services.work.WorkArea,\
org.eclipse.virgo.repository.ArtifactBridge,\
org.eclipse.virgo.kernel.shell.state.StateService,\
org.eclipse.virgo.kernel.shell.CommandExecutor,\
org.eclipse.virgo.repository.RepositoryFactory,\
org.eclipse.virgo.repository.HashGenerator,\
org.eclipse.virgo.medic.eventlog.EventLoggerFactory,\
org.eclipse.virgo.repository.Repository,\
org.eclipse.virgo.kernel.core.Shutdown,\
org.osgi.service.event.EventAdmin,\
org.osgi.service.log.LogService,\
org.eclipse.virgo.medic.eventlog.EventLogger,\
org.eclipse.virgo.medic.dump.DumpGenerator,\
org.eclipse.virgo.kernel.shim.scope.ScopeFactory,\
org.eclipse.virgo.kernel.shim.serviceability.TracingService,\
org.eclipse.virgo.kernel.model.RuntimeArtifactRepository,\
org.eclipse.osgi.service.resolver.PlatformAdmin,\
org.osgi.service.packageadmin.PackageAdmin,\
org.eclipse.virgo.kernel.core.ConfigurationExporter
serviceExports =\
org.eclipse.virgo.kernel.install.artifact.InstallArtifactLifecycleListener,\
org.eclipse.virgo.kernel.install.artifact.ArtifactIdentityDeterminer,\
org.eclipse.virgo.kernel.install.pipeline.stage.transform.Transformer,\
org.eclipse.virgo.kernel.module.ModuleContextAccessor,\
org.eclipse.virgo.medic.dump.DumpContributor,\
org.eclipse.virgo.kernel.osgi.quasi.QuasiFrameworkFactory,\
org.eclipse.virgo.kernel.osgi.framework.OsgiFramework,\
org.eclipse.virgo.kernel.osgi.framework.ImportExpander,\
org.eclipse.virgo.kernel.osgi.framework.PackageAdminUtil,\
org.osgi.service.event.EventHandler,\
org.osgi.framework.BundleContext,\
org.eclipse.virgo.kernel.deployer.config.ConfigurationDeployer
initialArtifacts=repository:plan/org.eclipse.virgo.kernel.userregion.springdm, repository:plan/org.eclipse.virgo.web.tomcat,repository:plan/server.plan
thanks agine.
| Re: userregionfactory failed to start [message #764589 is a reply to message #760686] |
Mon, 12 December 2011 08:40  |
Borislav Kapukaranov Messages: 80 Registered: September 2010 |
Member |
Have you made any modifications to the repository configuration in config/org.eclipse.virgo.repository.properties?
If you are running in a VM image then your file operations will be rather slow. When booting the repository bundle performs some analysis of the configured repositories so it could take more than the hardcoded 30 seconds on a slow machine.
If you added a new repository to the configuration that could potentially be the cause.
Borislav
Current Time: Sun May 19 16:52:00 EDT 2013
Powered by FUDForum. Page generated in 0.02118 seconds
