Home » General (non-technical) » Polish users » Convert Eclipse Java to Eclipse JaveEE
Convert Eclipse Java to Eclipse JaveEE [message #764128] Sun, 11 December 2011 07:34 Go to next message
Anand  is currently offline Anand
I recently downloaded Eclipse IDE for Java Developers. But i actually require Eclipse IDE for Java EE Developers. Is there anyway to convert the existing IDE to Java EE Developer's IDE without downloading the entire Java EE Developer's IDE?
Thank you.
Re: Convert Eclipse Java to Eclipse JaveEE [message #764201 is a reply to message #764128] Sun, 11 December 2011 11:39 Go to previous messageGo to next message
Tomasz Zarna is currently offline Tomasz Zarna
Hi Anand,
Have a look at the Compare Eclipse Packages chart. The first column shows what is included in Eclipse for Java, the second is for the JEE package. I would start from adding (installing with the Update Manager using an update site) WTP and Datatools.
Drop a line if you need more help.
Re: Convert Eclipse Java to Eclipse JaveEE [message #764586 is a reply to message #764201] Mon, 12 December 2011 08:32 Go to previous message
Hi Zarna,
Thank you for the reply. I am doing it now. And i think it will work. Thanks a lot. Smile
Previous Topic:autouzupełnianie
Next Topic:Zmiana koloru okna
Current Time: Sat May 18 17:30:42 EDT 2013
Powered by FUDForum. Page generated in 0.02372 seconds
