Home » Modeling » Amalgam » [M2M] model2xhtml QVT problem
icon5.gif  [M2M] model2xhtml QVT problem [message #764508] Mon, 12 December 2011 05:21 Go to next message
Federico Pozzoni is currently offline Federico Pozzoni
i'm trying to create a model to model transformation to my metamodel( Following the book "Eclipse Modeling Project - A Domain-Specific Language (DSL) Toolkit"), more precisely i've to create a transformation to XML.
I'm stuck at the point where i've to delete the "mixed:EFeatureMapEntry" and extend flow and inline with XMLTypeDocumentRoot; section of the book is the following:
QVTO cannot currently deal with statements such as mixed += 'text'; because
mixed is of type EFeatureMapEntry and cannot be set with a string.
A workaround for this is to extend model elements that contain a string within
their serialized output by XMLTypeDocumentRoot. With that, we need to delete
their mixed:EFeatureMapEntry because XMLTypeDocumentRoot declares
one as well. Declaring this eSuperType for the Inline and Flow classes of our
xhtml.ecore model should take care of most elements we need. We'll add this
supertype to more elements as needed when creating our script. Additionally, we
need to change some attributes to be of type AnySimpleType (for example,
colspan in ThType). A nice feature of the QVTO editor is that it recognizes
model changes on-the-fly, so each update is immediately available.
Can anyone help with this section?
Can anyone suggest some alternatives for the creation of XML?
Re: [M2M] model2xhtml QVT problem [message #764534 is a reply to message #764508] Mon, 12 December 2011 06:31 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Frederico,
It's better to use the eclipse.modeling.m2m forum. I've added it to the
CC list of this reply, so no need to repost; be sure to follow up and
monitor that forum instead though. In that forum, it's a good idea to
prefix the subject with [QVTo]...
> Quote:
>> because
>> string within
>> delete
>> classes of our
>> add this
>> Additionally, we
>> recognizes
> Can anyone help with this section? Can anyone suggest some
Re: [M2M] model2xhtml QVT problem [message #764626 is a reply to message #764534] Mon, 12 December 2011 09:56 Go to previous message
Modern modeling tools work with models that have relatively simple
underlying structure (meta-meta-model) defined by Ecore/MOF/UML.
Pre-modeling tools based on XML can have very complex structure,
sometimes constrained by XSD.
Few modeling tools support the complexity of XSD at the modeling level.
In some cases you may be able to configure EMF's XML serialisation to
hide the external eccentricities from the tools, But more generally..
You must use a meta-meta-model that represents your concepts, so if you
are interested in the subtleties of XML serialisation you need to use
XSD as your meta-model (and perhaps Ecore as your meta-meta-model). ATL
certainly has examples of direct manipulation of XML.
Ed Willink
On 12/12/2011 03:31, Ed Merks wrote:
> Frederico,
> the CC list of this reply, so no need to repost; be sure to follow up
> and monitor that forum instead though. In that forum, it's a good
> idea to prefix the subject with [QVTo]...
>> Quote:
>>> because
>>> string within
>>> to delete
>>> classes of our
>>> add this
>>> Additionally, we
>>> example,
>>> recognizes
Previous Topic:Error while trying to build the requirements diagram
Next Topic:Feedback from Eclipse Modeling Package
Current Time: Tue May 28 08:19:06 EDT 2013
Powered by FUDForum. Page generated in 0.01657 seconds
