| Graphiti as Multiple Xml Editor [message #760438] |
Fri, 02 December 2011 06:30  |
mcd Messages: 4 Registered: December 2011 |
Junior Member |
Hello!
Im working on an Eclipse plugin. What I want to do is making a custom editor that can open xml files. I want to show a Flow diagram based on that file and I want to allow changes in the diagram. After saving the file I want to save back to Xml. Is it possible to do that?
If not, I have already parsed the Xml files and I have a EMF model that contains everything that the Xml files contains. Can I load a EMF object into Graphiti?
| Re: Graphiti as Multiple Xml Editor [message #763330 is a reply to message #763137] |
Fri, 09 December 2011 10:25   |
Junior Member |
I want to do an Eclipse graphical editor with Graphiti. What i want to do is to feed the editor with xml files and let the user edit (save, load, view) the xml file with a graphical tool.
And is it possible to feed the graphical editor from multiple xml files and save the graphical editor changes to multiple xml files?
The xml files has a predefined syntax.
I have already did a parser that parses all the xml files, and make an EMF Object (!).
[Updated on: Fri, 09 December 2011 10:27] Report message to a moderator
FUDForum. Page generated in 0.05123 seconds
