| Clone, share... and next, question marks decorators ? [message #763166] |
Fri, 09 December 2011 04:39  |
Harry Houdini Messages: 131 Registered: February 2010 |
What is what I do with EGit :
1. I clone with EGit a git remote depositery
2. As it is a C++ project, I run CMake to do a makefile project
3. I import the project in the C++ perspective as a makefile project
4. In the Project explorer, I do Team/Share project/Git
5. I select the .git in my clone's directory; Working directory is automatically set, I leave "Path within repository" blank, and I check the only choice in the list at the bottom of the window
All the files wich come from the depository are then tagged with the question mark decorator.
Are not they supposed to be tracked ?
The files which were generated by CMake after cloning have no decorator.
When I do "git status" on the command lines", all the "question marked" files are tagged as deleted, but not staged for commit.
It seems I don't understand some basis.
Thanks for help.
[Updated on: Fri, 09 December 2011 04:40] Report message to a moderator
| Re: Clone, share... and next, question marks decorators ? [message #763297 is a reply to message #763178] |
Fri, 09 December 2011 09:26   |
R Shapiro Messages: 308 Registered: June 2011 |
Try this instead:
1. In the Git Repository Exploring perspective, clone the repo, and in the third 'page' of Clone Git Repository dialog, where you enter the directory for the clone, check the box that says "Import all existing projects after clone finishes". Use the "Next" button to advance pages.
That's it -- no need to do anything else for Git configuration.
[Updated on: Fri, 09 December 2011 11:55] Report message to a moderator
FUDForum. Page generated in 0.01792 seconds
