Home » Modeling » M2T (model-to-text transformation) » index inside for
index inside for [message #759615] Tue, 29 November 2011 05:58 Go to next message
Eclipse User
I want to use the "i" var feature inside a for loop
Try to do :
[for (str : String | ... )]
[str.toString()/]=[i/];
[/for]
But I have a syntax error
What do I miss
Thank you
Re: [Acceleo 3] index inside for [message #759648 is a reply to message #759615] Tue, 29 November 2011 08:13 Go to previous messageGo to next message
Eclipse User
Sorry for overposting, I forgot to tag my post with [Acceleo 3]
I Try to do :
[/for]
But I have a syntax error about i not recongnized...
What do I miss ?
Thank you
Re: [Acceleo 3] index inside for [message #760087 is a reply to message #759648] Thu, 01 December 2011 04:20 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
Hi Cédric,
The "i" variable is there since 3.0 and should be recognized whenever you are inside of a for. Which version of Acceleo are you using? Maybe you could you provide us with a sample module that presents this issue? A basic test on my side did compile correctly.
Laurent Goubet
Obeo
Re: [Acceleo 3] index inside for [message #762021 is a reply to message #760087] Wed, 07 December 2011 07:49 Go to previous messageGo to next message
Eclipse User
Hi Laurent
Sorry for the delay of my answer
Here the code I use :
[for (str : String | sm.eAllContents(State)
->select(s | not(s.isComposite))
->collect(st | sm.getNormalizedName().toUpper() +
st.getNormalizedName().toUpperFirst()) ) separator (',\n')]
[str.toString()/]=[i/][/for]
And the error is :
Error : An error occured while saving generate.emtl : The object 'i :
Integer' is not contained in a resource.
My version of acceleo is : 3.1.1 (2011 14 09)
What do I miss ?
Best regards
Re: [Acceleo 3] index inside for [message #762026 is a reply to message #762021] Wed, 07 December 2011 07:59 Go to previous message
Hi Cedric,
Ok, that's not "not recognized" but indeed a bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=357770) Smile. Unfortunately, this bug made it in the 3.1.1 build (it was fixed the day after we built that version).
I can get an integration build of the 3.1.2 ready today if you need this fixed in the 3.1 stream, otherwise you should be safe using the 3.2 stream.
Laurent Goubet
Obeo
Previous Topic:[Acceleo] Progress Reporting
Next Topic:[Acceleo] how to get the ID of an EObject
Current Time: Wed May 22 19:45:34 EDT 2013
Powered by FUDForum. Page generated in 0.01869 seconds
