| XML schema "fixed" attribute and static final fields [message #76192] |
Tue, 11 November 2008 14:01  |
John T.E. Timm Messages: 160 Registered: July 2009 |
I am having some issues with EMF 2.4 generating static final fields that
correspond to the "fixed" attribute in the schema definition. For example,
using this snippet my from XML Schema definition:
<xs:attribute name="classCode" type="RoleClass" use="optional"
default="BIRTHPL"/>
Under EMF 2.2, this is what gets generated:
protected static final Object CLASS_CODE_DEFAULT =
CDAR2Factory.eINSTANCE.createFromString(CDAR2Package.getRole Class(),
"BIRTHPL");
protected Object classCode = CLASS_CODE_DEFAULT;
Under EMF 2.4, this is what gets generated:
protected static final Object CLASS_CODE_DEFAULT; // TODO: the default
literal value "BIRTHPL" is not valid.
which obviously fails compilation due to unassigned static final field.
What has changed between the two EMF versions that would cause this issue?
Is there a workaround?
JT
| Re: XML schema "fixed" attribute and static final fields [message #603436 is a reply to message #76192] |
Tue, 11 November 2008 14:24  |
Ed Merks Messages: 24550 Registered: July 2009 |
John,
Comments below.
> that correspond to the "fixed" attribute in the schema definition. For
> example, using this snippet my from XML Schema definition:
> default="BIRTHPL"/>
> "BIRTHPL");
Probably I need to see more of the schema. What does RoleClass look
like? I wonder why its type would be java.lang.Object and not something
more specific...
> issue? Is there a workaround?
If you provide a test case I can use the reproduce the problem, I'll
look into it.
> JT
FUDForum. Page generated in 0.09006 seconds
