Home » Eclipse Projects » Rich Client Platform (RCP) » Get Plugin-Version String from within eclipse
Get Plugin-Version String from within eclipse [message #760818] Mon, 05 December 2011 06:07 Go to next message
Alexander  is currently offline Alexander
Hi there,
searched all over the web, but didn't find anything regarding my problem.
I'd like to write a plugin with a new menu and there an "about" menu entry. There I'd like to see the actual version of my plugin. I.e. if I set the Version in the project settings to "2.4.1.alpha", I'd like to see this string in an about message box opened from the menu entry.
Is there a way to do this?
Thanks in advance
Alex
Re: Get Plugin-Version String from within eclipse [message #761293 is a reply to message #760818] Tue, 06 December 2011 03:49 Go to previous messageGo to next message
Eclipse User
Hi Alex,
I do this by the following snippet:
Version version = YourPlugin.getDefault().getBundle().getVersion()
Is this what you need?
best regards,
Gilbert
Re: Get Plugin-Version String from within eclipse [message #761908 is a reply to message #761293] Wed, 07 December 2011 04:09 Go to previous message
Yep, that's it! Thanks for the support.
To make it clear for other people, I used a slight different line:
String sVersion = MyPluginPackage.Activator.getDefault().getBundle().getVersion().toString();
Previous Topic:RCP Exception
Next Topic:Missing Constraint:... org.apache.lucene; bundle-version=[1.9.0;2.0.0)
Current Time: Fri May 24 15:31:10 EDT 2013
Powered by FUDForum. Page generated in 0.01596 seconds
