Home » Eclipse Projects » BIRT » Interactive chart(Interactive chart)
Interactive chart [message #759894] Wed, 30 November 2011 08:50 Go to next message
srikanth Missing name is currently offline srikanth Missing name
Member
Hi all,
Is there a way we can generate a interactive chart in BIRT.For example, A chart is generated and is there a way the user can click on any segment of the generated report and we can generated another report..
any suggestions will be really helpfull..
Srikanth
Re: Interactive chart [message #759979 is a reply to message #759894] Wed, 30 November 2011 14:05 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Sure just use the hyperlink builder in the third tab of the chart wizard
(interactivity) to point to drill through. In fact you can have a data
point have multiple drill through paths. I am posting two interactivity
posts I did a while ago, that show invoking client side script.
http://birtworld.blogspot.com/2009/12/calling-client-side-javascript-from.html
http://birtworld.blogspot.com/2010/05/more-on-chart-interactivity.html
While you do not need these they should show you how to open the
interactivity editor.
Btw BIRT also supports server side scripting on chart.
http://birtworld.blogspot.com/2010/08/birt-charting-scripting-overview.html
Jason
On 11/30/2011 8:50 AM, srikanth wrote:
> Hi all,
> Srikanth
Jason Weathersby
BIRT Exchange
Re: Interactive chart [message #761410 is a reply to message #759979] Tue, 06 December 2011 07:47 Go to previous messageGo to next message
Member
Thank you Jason.... It was really helpful..
I am trying out the following features can you please help me out with them,
1)AD HOC REPORTING
2)DASHBOARDS
Srikanth
[Updated on: Tue, 06 December 2011 07:47]
Report message to a moderator
Re: Interactive chart [message #761573 is a reply to message #761410] Tue, 06 December 2011 12:13 Go to previous message
On ad hoc reporting do you mean changing the report based on parameters?
If so this can be done by using scripting or property binding to
modify the query that is executed or by using the design engine api in
the beforeFactory event to alter the report. There are many examples of
this on birtworld and birt-exchange dev share.
On dashboards, you could use the BIRT tag libraries to do this?
http://www.eclipse.org/birt/phoenix/deploy/viewerUsageMain.php#tags
If you only want to render one portion of a report say a chart put a
bookmark property on it in the design and then use the reportletid
attribute. You may also want to look over this post:
http://birtworld.blogspot.com/2007/09/22-birt-tag-library-building-custom.html
Jason
On 12/6/2011 7:47 AM, srikanth wrote:
> Thank you Jason.... It was really helpfull..
> I am trying out the following features can you please help me out with the,
> 1)AD HOC REPORTING
> 2)DASHBOARDS
> Srikanth
Jason Weathersby
BIRT Exchange
Previous Topic:Can Java and BIRT use same Oracle database session connection
Next Topic:Specifying the number of rows per page
Current Time: Sat May 25 00:01:24 EDT 2013
Powered by FUDForum. Page generated in 0.01650 seconds
