| "Handler service cannot be null" exception in launching eclipse product. [message #761451] |
Tue, 06 December 2011 08:49  |
Raj Messages: 1 Registered: December 2011 |
Junior Member |
I am working on upgrading eclipse application from 3.2 to eclipse 4.1.1
buildId=M20110912-1510
java.version=1.6.0_12
When I will try to launch the eclipse it throws following exception
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException: The handler service cannot be null
org.eclipse.ui.internal.commands.WorkbenchCommandSupport.<init>(WorkbenchCommandSupport.java:75)
org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:1893)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1526)
at org.eclipse.ui.internal.Workbench.access$36(Workbench.java:1481)
at org.eclipse.ui.internal.Workbench$66.run(Workbench.java:2592)
I had tried many configuration settings but still no luck. Can anyone know the cause of this exception?
Please let me know if there is any guide available to upgrade from 3.2 to 4.1.1
FUDForum. Page generated in 0.01512 seconds
