Home » Modeling » Modeling (top-level project) » Tagging model elements using toolbar
Tagging model elements using toolbar [message #761414] Tue, 06 December 2011 07:53 Go to next message
Frederik.Gailly is currently offline Frederik.Gailly
I am developing a modeling tool which must make it easier to annotate the elements of my diagram with some tags that are available in the tool bar. For every tag I have added a creation tool to my gmfTool model. When the modeler drags one of the tools to an entity the corresponding tag must be added to the entity in a similar way that stereotypes are added to an entity.
The problems that I am facing are:
- I cannot hard code a value when I use a feature label mapping
- I have a added the tags to a compartment. However because this compartment is used in combination with different children reference in my gmfmap, the model creates a compartment for every tag.
Thank you
Re: Tagging model elements using toolbar [message #761429 is a reply to message #761414] Tue, 06 December 2011 08:17 Go to previous message
Ed Merks is currently offline Ed Merks
Please use eclipse.modeling.gmf for questions about GMF.
On 06/12/2011 4:53 AM, Frederik.Gailly wrote:
> Thank you
Previous Topic:serious help needed with EMF and JEt
Next Topic:Survey on Model Execution
Current Time: Tue May 21 00:56:52 EDT 2013
Powered by FUDForum. Page generated in 0.01526 seconds
