| Problem with Linuxtool installation [message #761353] |
Tue, 06 December 2011 05:39  |
Sahar Messages: 2 Registered: December 2011 |
Junior Member |
I faced a problem in the installation of LinuxTool. I am on Ubuntu Lucid 10.04. I wrote the following repository in "install new software" dialog box:
Eclipse Linux Tools p2 Repository (Incubation) - http:://download.eclipse.org/technology/linuxtools/update
and then selected "Linux Tools". But I got this error:
Software being installed: Profile Framework (Incubation) 0.9.0.201111050234 (org.eclipse.linuxtools.profiling.feature.group 0.9.0.201111050234)
Missing requirement: Profile Framework (Incubation) 0.9.0.201111050234 (org.eclipse.linuxtools.profiling.feature.group 0.9.0.201111050234) requires 'org.eclipse.cdt.feature.group 7.0.0' but it could not be found
To understand which packages make this error, I unselected all packages under "Linux Tool" and tried to install them one by one. Out of 15 packages in LinuxTools, the installation of the following packages were unsuccessful:
ChangeLog Management Tools (Incubation)
LTTng - Linux Tracing Toolkit (Incubation)
OProfile Integration (Incubation)
RPM Import/Export and Building Tool (Incubation)
Valgrind Tools Integration (Incubation)
I wonder what are the prerequisites for "linux tools". I have already installed cdt for running my cpp codes and also "Test and Performance Tools Project" (tptp). But I found tptp unuseful for profiling my c++ codes, then I decided to install linuxtools to have valgrind integrated in eclipse. I will appreciate any help, I've spent much time on this problem, yet unresolved.
| Re: Problem with Linuxtool installation [message #770542 is a reply to message #770114] |
Sat, 24 December 2011 10:41  |
Francois Chouinard Messages: 28 Registered: July 2009 |
Junior Member |
The version of LTTng you are trying to install has a dependency on RSE (Remote System Explorer) to access and control the tracer - the LTTng tracer tool itself. This feature was introduced with Indigo and, if I remember well, was also working for Helios.
You could try to install RSE 3.2 before updating the Linux Tools but I'm not sure it is compatible with Galileo. You should be able to find RSE under Target Management (TM) which was still a sub-project of DSDP in the Galileo days (it is now under Tools).
If I may ask: Is there any reason not to upgrade to Indigo?
/fc
FUDForum. Page generated in 0.02520 seconds
