| xtext.completeocl.ui export packages [message #760993] |
Mon, 05 December 2011 13:55  |
safouan.taha Messages: 2 Registered: December 2011 Location: France |
Junior Member |
Dear OCL committers.
This is my first time on this forum.
First, Thank you for the huge work you are doing.
May I ask a small favor? : could you please export from the "org.eclipse.ocl.examples.xtext.completeocl.ui" plugin these packages :
-- org.eclipse.ocl.examples.xtext.completeocl.ui.contentassist,
-- org.eclipse.ocl.examples.xtext.completeocl.ui.labeling,
-- org.eclipse.ocl.examples.xtext.completeocl.ui.outline
I would like to use/import the complete ocl parser from Eclipse plugins I am developing
Sincerely.
[Updated on: Mon, 05 December 2011 13:58] Report message to a moderator
| Re: xtext.completeocl.ui export packages [message #761313 is a reply to message #761110] |
Tue, 06 December 2011 04:22  |
Ed Willink Messages: 3175 Registered: July 2009 |
Should be in GIT now.
[If you're extending the editors, you may have come across the very
limited quality of the default completion proposals. It may be some time
before these get to the top of my priority stack, so if you have
anything to contribute that would be welcome.]
Ed Willink
On 05/12/2011 23:01, safouan.taha wrote:
> As you suggested, I put it on bugzilla.
> If you can do it for M4, it would be perfect for me.
> I have seen the API changing many times, but it's worth it ;)
> Thank you again
FUDForum. Page generated in 0.01704 seconds
