Home » Modeling » Modeling (top-level project) » serious help needed with EMF and JEt
| serious help needed with EMF and JEt [message #760964] |
Mon, 05 December 2011 13:06  |
I wrote a plugin to generate additional java source needed for my
application. It worked well under Galileo. Now under Helios I'm seeing
almost random inexplicable behavior. For example, code being generated
even when the plugin has been removed...
<plugin>
<extension point="org.eclipse.emf.codegen.ecore.generatorAdapters">
<!-- Adapter Factory -->
<adapterFactory
class="com.sye.eclipse.emf.generator.dal.DalGeneratorAdapterFactory"/>
<!-- Single Adapter -->
<adapter modelClass="GenModel"
class="org.eclipse.emf.examples.generator.dal.GenModelDalGeneratorAdapter"/>
<adapter modelClass="GenClass"
class="org.eclipse.emf.examples.generator.dal.GenClassDalGeneratorAdapter"/>
</extension>
I'm extending generatorAdapters
Originally my plugin had a Templated/model folder with my single
template. The target EMF project also had a Template/model folder
having modified templates: Class.javajet and FactoryClass.javajet.
These over-rode standard gen behavior. Now they are invisible...
Is there a tutorial or article about extending EMF code gen and
over-riding standard generation?
Thanks!!!!!!!!!!!!!!!!!!!
Roy
| Re: serious help needed with EMF and JEt [message #760983 is a reply to message #760972] |
Mon, 05 December 2011 13:46   |
Hi Ed,
I'll use eclipse.tools.emf next time.
It's been a year since I worked on this. More than anything I think I
forgot the recipe...
I have "templates" for Template Directory, in the genmodel (which is new).
The two templates located there (Class.javajet and factoryClass.javajet
seem "invisible", i.e. not being used during generation.
The real folder is templates/model, not just templates.
Roy
On 12/5/2011 10:20 AM, Ed Merks wrote:
> Roy,
> Please use eclipse.tools.emf for questions about EMF in the future. More
> comments below...
> On 05/12/2011 10:06 AM, Roy Benjamin wrote:
>> <plugin>
>> <adapterFactory
>> </extension>
> And you have settings in your GenModel to set up the template path? (I
> suppose you followed the FAQ for this.)
> What things are invisible? These folders with the templates?
> No. There an example for using the generator adapters, but I've not seen
> that you've added new template but rather are just wanting dynamic
> templates (as in the FAQ).
> When in doubt, be sure to unfilter .* resources and look at whether the
> ..JETEmitters project might be messed up. You can delete it completely,
> including deleting it from the file system, and it will be regenerated
> the next time you generate. You might want to close and reopen the
> generator after such a cleanup...
>> Roy
| Re: serious help needed with EMF and JEt [message #760987 is a reply to message #760972] |
Mon, 05 December 2011 13:49   |
Also am seeing cast exception in the template:
<%final GenClass genClass = (GenClass)((Object[])argument)[0]; final
GenPackage genPackage = genClass.getGenPackage(); final GenModel
genModel=genPackage.getGenModel();%>
after changing template path to templates/model
Roy
java.lang.ClassCastException:
org.eclipse.emf.codegen.ecore.genmodel.impl.GenClassImpl incompatible
with [Ljava.lang.Object;
org.eclipse.emf.codegen.ecore.templates.model.Class_.generate(Class_.java:1793)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:599)
at org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.java:467)
org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generateJava(AbstractGeneratorAdapter.java:981)
com.ebay.eclipse.emf.generator.dal.GenClassDalGeneratorAdapter.generateModel(GenClassDalGeneratorAdapter.java:92)
org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGeneratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:221)
org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generate(AbstractGeneratorAdapter.java:290)
org.eclipse.emf.codegen.ecore.generator.Generator.generate(Generator.java:617)
org.eclipse.emf.codegen.ecore.genmodel.presentation.GeneratorUIUtil$GeneratorOperation.execute(GeneratorUIUtil.java:167)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
> Roy,
> comments below...
>> <plugin>
>> <adapterFactory
>> </extension>
>> Roy
| Re: serious help needed with EMF and JEt [message #761010 is a reply to message #760987] |
Mon, 05 December 2011 14:12   |
Ed Merks Messages: 24570 Registered: July 2009 |
Roy,
I think you'll need to revisit your copied template to make sure it
works with the latest code. I see the stack below is being initiated by
your own adapter GenClassDalGeneratorAdapter so I can't comment on what
it's doing.
> Thanks
> Roy
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Roy,
>> comments below...
>>> Hi,
>>> <plugin>
>>> <adapterFactory
>>> </extension>
>>> Roy
| Re: serious help needed with EMF and JEt [message #761052 is a reply to message #761010] |
Mon, 05 December 2011 15:18   |
Hi Ed,
You are right. In my adapter I used to pass null for arguments in
generateModel(Object,Monitor).
generateJava(targetPath, packageName, className, jetEmitter, null,
monitor2);
Somehow a GenClass instance was passed as the argument anyway.
Even if I get the correct arguments passed for the genClass case I'm not
sure how I'll know to pass genPackage for FactoryClass.javajet since
there is no genPackage() function.
I have to get this working again so I'll keep working.
Roy
On 12/5/2011 11:12 AM, Ed Merks wrote:
> Roy,
> it's doing.
>> Thanks
>> Roy
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Roy,
>>> comments below...
>>>> Hi,
>>>> <plugin>
>>>> <adapterFactory
>>>> </extension>
>>>> Roy
| Re: serious help needed with EMF and JEt [message #761062 is a reply to message #761010] |
Mon, 05 December 2011 15:45  |
in my generated Class_.java I have:
System.out.println("*******************************************************************\n"+argument);
System.out.println("*******************************************************************");
stringBuffer.append(TEXT_2);
genModel=genPackage.getGenModel(); <--------------------------------
cast exception on this line
System.out.println("\n0----------------------------------------------------------------\n");
The runtime output is:
org.eclipse.emf.codegen.ecore.genmodel.impl.GenClassImpl@5b905b9
(provider: Singleton, image: true, dynamic: false)
!ENTRY org.eclipse.emf.codegen.ecore 2 0 2011-12-05 12:39:14.554
!MESSAGE org.eclipse.emf.codegen.jet.JETException: InvocationTargetException
!STACK 0
org.eclipse.emf.common.util.WrappedException:
org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generateJava(AbstractGeneratorAdapter.java:1112)
com.ebay.eclipse.emf.generator.dal.GenClassDalGeneratorAdapter.generateModel(GenClassDalGeneratorAdapter.java:99)
So, it looks like an instance of GenClassImpl cannot be cast to
interface GenClass. I've only seen something like this for classloader
problems.
> Roy,
> it's doing.
>> Thanks
>> Roy
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Roy,
>>> comments below...
>>>> Hi,
>>>> <plugin>
>>>> <adapterFactory
>>>> </extension>
>>>> Roy
Current Time: Tue May 28 15:48:12 EDT 2013
Powered by FUDForum. Page generated in 0.01784 seconds
