Home » Modeling » TMF (Xtext) » link reference issue
link reference issue [message #760435] Fri, 02 December 2011 06:28 Go to next message
Vlad Dumitrescu is currently offline Vlad Dumitrescu
Hi!
I have some rule like
Function: Clause (';' Clause)* '.' ;
Clause: ID '(' Args ')' '->' Expressions ;
Each clause has the same name (ID) and it actually belongs naturally to the function itself. Is there a way to let the function inherit the name from the first clause without changing the grammar?
The grammar change feels inelegent
Function: ID Clause0 (';' Clause)* '.' ;
Clause0 returns Clause: '(' Args ')' '->' Expressions ;
best regards,
Vlad
Re: link reference issue [message #760596 is a reply to message #760435] Sat, 03 December 2011 05:20 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
am not sure what you exactly want to do since you dont have any assignments in your grammar which is abolutely unrealisitic. never the less if you want to calculate a qualified name (the thing that is used for cross references) with a custom logic this is usually done in the IQualifiedNameProvider. so subclassing and customizing DefaultDeclarativeQualifiedNameProvider should do the trick.
~Christian
Re: link reference issue [message #760616 is a reply to message #760596] Sat, 03 December 2011 09:48 Go to previous messageGo to next message
Hi Christian!
Well the example was stripped down of assignments, of course they are present in the full grammar.
Thanks a lot for the pointers, I will look at IQualifiedNameProvider. I suppose it's the same place to look at if the references are not just names but may be more complicated expressions?
best regards,
Vlad
Re: link reference issue [message #760618 is a reply to message #760616] Sat, 03 December 2011 10:22 Go to previous messageGo to next message
you may have a look at this blog http://blogs.itemis.de/stundzig/archives/773 and its follow ups to be a basic understanding of the topic
~Christian
Re: link reference issue [message #760653 is a reply to message #760618] Sat, 03 December 2011 16:37 Go to previous message
Great! Thanks Christian!
regards,
Vlad
Previous Topic:Trigger JDT JavaDoc Formatter for Doc-Comments
Next Topic:[Xtend2] Generating user editable C++ code
Current Time: Wed May 22 21:36:49 EDT 2013
Powered by FUDForum. Page generated in 0.01604 seconds
