| Running e4 as IDE causes curious errors [message #760630] |
Sat, 03 December 2011 12:48  |
erru Mising name Messages: 3 Registered: October 2011 |
Junior Member |
I have a problem running e4 (32bit) as IDE on my Lenovo T500 with Windows 7 64 bit and Java 32 bit.
During work I get the following error:
!SESSION 2011-12-03 18:16:07.847 -----------------------------------------------
eclipse.buildId=I20110620-1631
java.version=1.6.0_26
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=default
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.e4.ui.workbench 4 0 2011-12-03 18:25:40.844
!MESSAGE Internal Error
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTError: No more handles
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:75)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:88)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:326)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:343)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:596)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activateBranch(EclipseContext.java:601)
at org.eclipse.e4.ui.internal.workbench.PartActivationHistory.activate(PartActivationHistory.java:52)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:529)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:488)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2320)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4572)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4985)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2525)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3095)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3749)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:969)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:885)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:87)
at org.eclipse.ui.internal.Workbench$3.run(Workbench.java:539)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:519)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4308)
at org.eclipse.swt.SWT.error(SWT.java:4197)
at org.eclipse.swt.SWT.error(SWT.java:4168)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Control.createHandle(Control.java:704)
at org.eclipse.swt.widgets.Label.createHandle(Label.java:199)
at org.eclipse.swt.widgets.Control.createWidget(Control.java:744)
at org.eclipse.swt.widgets.Control.<init>(Control.java:112)
at org.eclipse.swt.widgets.Label.<init>(Label.java:101)
at org.eclipse.ui.texteditor.StatusLineContributionItem.fill(StatusLineContributionItem.java:182)
at org.eclipse.jface.action.SubContributionItem.fill(SubContributionItem.java:59)
at org.eclipse.jface.action.StatusLineManager.update(StatusLineManager.java:326)
at org.eclipse.ui.internal.WorkbenchPage.updateActivations(WorkbenchPage.java:254)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:232)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:160)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:187)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.setPart(PartServiceImpl.java:161)
at sun.reflect.GeneratedMethodAccessor27.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 134 more
When I going on with my work, I got the following errors:
1. Del-Key not working
2. Ctrl-C and Ctr-V not working (sometimes the paste go into an inactive edit, but not in the one, that has the focus
3. Search isn´t working anymore. Search finds nothing in my documents.
I try to download e4 and run it from another directory but I always get the same errors.
So now I am at a point, where I don´t now what to do.
I hope, someone give me a tip.
I don´t know, how to find the error.
| Re: Running e4 as IDE causes curious errors [message #760695 is a reply to message #760630] |
Sun, 04 December 2011 05:31   |
Thomas Schindl Messages: 4462 Registered: July 2009 |
This means there is some kind of resource leak. Do you have any other
plugins installed? It would be interesting to find out who consumes
those resources.
You could try using Sleak [1] to find out which handles are consumed.
Tom
[1]http://www.eclipse.org/swt/tools.php
Am 03.12.11 18:48, schrieb erru:
> Hi
> !STACK 0
> more handles
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 134 more
> the same errors.
> Thanks
| Re: Running e4 as IDE causes curious errors [message #760855 is a reply to message #760695] |
Mon, 05 December 2011 08:13  |
Junior Member |
Hi Tom,
thanks for your reply.
I have installed sleak, but I can´t detect in which plugin the error occurs.
The error occurs when I start eclipse and then click on any breakpoint in the editor view. The icons in the toolbar flicker and then the SWTError comes up.
I have made a video, where you can see the behavior.
You can see it here: www.vidup.de/v/Q7m29/
FUDForum. Page generated in 0.01603 seconds
