Home » Eclipse Projects » Standard Widget Toolkit (SWT) » masked value for swt text field based on indicator
masked value for swt text field based on indicator [message #759834] Wed, 30 November 2011 04:18 Go to next message
sam mn is currently offline sam mn
trying to make characters typed into a text into masked ones based on a checkbox indicator.
tried the below code, but it is not working:
valueText.addModifyListener(new ModifyListener() {
public void modifyText(ModifyEvent e) {
if(maskIndicator.getSelection()){
valueText.setEchoChar('*');
why is echoChar not working??
can someone guide me, what i am doing wrong here.
[Updated on: Wed, 30 November 2011 11:14]
Report message to a moderator
Re: masked value for swt text field based on indicator [message #760124 is a reply to message #759834] Thu, 01 December 2011 06:52 Go to previous messageGo to next message
Lakshmi Shanmugam
setEchoChar() doesn't work for Text with SWT.MULTI style. Are you using SWT.MULTI or SWT.SINGLE style?
Also, since you are using the echo character based on the checkbox indicator, it is better to set and unset the echo character using setEchoChar() in the checkbox's selection listener.
Lakshmi P Shanmugam
Re: masked value for swt text field based on indicator [message #760340 is a reply to message #760124] Thu, 01 December 2011 20:08 Go to previous messageGo to next message
Thanks for the SWT.Single info Lakshimi.
how do we unset echochar?
Re: masked value for swt text field based on indicator [message #760355 is a reply to message #760340] Fri, 02 December 2011 01:11 Go to previous message
Lakshmi Shanmugam
From javadoc of setEchoChar "...setting the echo character to '\0' clears the echo character and redraws the original text"
Lakshmi P Shanmugam
Previous Topic:StyledText with Image?
Next Topic:How to scroll in this composite with Page-Up/Down?
Current Time: Sat May 25 14:49:35 EDT 2013
Powered by FUDForum. Page generated in 0.01886 seconds
