Home » Eclipse Projects » EclipseLink » @Version and DescriptorException
@Version and DescriptorException [message #760321] Thu, 01 December 2011 15:57 Go to next message
Mauro is currently offline Mauro
Member
I have an entity called Foo with an embedded class Boo. Both classes are declared in my persistence.xml. Boo is packaged in different jar than Foo. Foo is packaged in an EJB jar; Boo is packaged in an utility jar (app-inf/lib). Boo has a timestamp property.
Both jar are deployed and run successfully.
When I put @Version on timestamp property of Boo, I get following exception:
Exception [EclipseLink-93] (Eclipse Persistence Services - 2.1.3.v20110304-r9073): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The table [FOO] is not present in this descriptor.
Descriptor: RelationalDescriptor(Foo --> [DatabaseTable(FOO)])
If I package Foo and Boo in the same ejb jar, this exception is not shown.
Thanks for any help.
Re: @Version and DescriptorException [message #761030 is a reply to message #760321] Mon, 05 December 2011 14:40 Go to previous message
James Sutherland is currently offline James Sutherland
Odd. Can you include the full exception stack trace.
James : Wiki : Book : Blog
Previous Topic:Server startup FileNotFoundException
Next Topic:NPE and other unmotivated exceptions
Current Time: Fri May 24 21:39:58 EDT 2013
Powered by FUDForum. Page generated in 0.02134 seconds
