Home » Eclipse Projects » BIRT » Reg:DataEngine_xxxxxx_xxx (DataEngine_279358987_54 and ReportingEngine Configuration.)
Reg:DataEngine_xxxxxx_xxx [message #758464] Wed, 23 November 2011 06:35 Go to next message
harip kaligo is currently offline harip kaligo
Member
hi,
We observed that when a report is being generated, a directory DataEngine_279358987_54 is created in /tmp location of our linux servers. We have set the below options for our reportengine:
config.getAppContext().put(DataEngine.MEMORY_USAGE, DataEngine.MEMORY_USAGE_CONSERVATIVE);
config.getAppContext().put(DataEngine.MEMORY_BUFFER_SIZE, birtProperties.getBirtMemoryBufferSize(key));
Is there document available to understand the siginificance of these parameters.
While running reports we get DataEngine directories deleted automatically after data is fetched from Database,is this anything to do with the option we set above?.
Sometimes we get the reports errored out with an exception in the file attached.
Please advise on the configuration of the reportengine to run 30 reports in parallel with each report having around 30k records.
KKP
Re: Reg:DataEngine_xxxxxx_xxx [message #758537 is a reply to message #758464] Wed, 23 November 2011 10:37 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
This setting:
sets the max memory used per query before caching to disk. It defaults to 10 MB. What are you setting it to?
The data engine files are cached data files. The conservative memory usages setting configures settings form max memory for olap operations I believe. Do your reports use crosstabs?
What version of BIR are you using? The exception looks like a bug.
Jason
Jason Weathersby
BIRT Exchange
[Updated on: Wed, 23 November 2011 10:37]
Report message to a moderator
Re: Reg:DataEngine_xxxxxx_xxx [message #758639 is a reply to message #758537] Wed, 23 November 2011 22:44 Go to previous messageGo to next message
Member
Jason,
We do not have any cross tab reports.Could you please suggest what needs to be set to remove all data caching as its occupying more space and reports are erroring out with exception: No disk space left.
The exception attached in file occurs intermittently and not sure about the root cause.
Is there any implication if we delete DataEngine while the report generation is in process.
Below is the list of versions used:
BIRT version 3.7
Application Server:Weblogic10.0.2
OS:LINUX
JDK:1.5
DB:Oracle 10g
KKP
Re: Reg:DataEngine_xxxxxx_xxx [message #759472 is a reply to message #758639] Mon, 28 November 2011 14:04 Go to previous messageGo to next message
Have you tried putting a higher value in
I believe this will cause problems if you delete the files.
Jason
On 11/23/2011 10:44 PM, kkp wrote:
> Jason,
> the root cause.
> BIRT version 3.7
> OS:LINUX
> JDK:1.5
> DB:Oracle 10g
> KKP
Jason Weathersby
BIRT Exchange
Re: Reg:DataEngine_xxxxxx_xxx [message #760209 is a reply to message #759472] Thu, 01 December 2011 10:45 Go to previous messageGo to next message
Member
We have set it to 2MB.Even aftre removing this property, we are still facing the issue.
Re: Reg:DataEngine_xxxxxx_xxx [message #760221 is a reply to message #760209] Thu, 01 December 2011 11:02 Go to previous message
Can you open a bugzilla entry for this?
Jason
> facing the issue.
Jason Weathersby
BIRT Exchange
Previous Topic:BIRT viewer /frameset syntax in INDEX.JSP
Next Topic:Page Numbering when using RunAndRender in 3.7.1
Current Time: Sat May 25 13:26:01 EDT 2013
Powered by FUDForum. Page generated in 0.01713 seconds
