Home » Eclipse Projects » XML Schema Definition (XSD) » xsd export
xsd export [message #75996] Fri, 24 October 2008 06:24 Go to next message
gitanjali punj is currently offline gitanjali punj
Member
Can you tell me how to convert an ecore model to xsd through
emf UI?
Re: xsd export [message #76013 is a reply to message #75996] Fri, 24 October 2008 06:54 Go to previous message
Ed Merks is currently offline Ed Merks
Gitanjali,
Open the associated *.genmodel and from the main menu bar, invoke
Generator->Export Model...->XML Schema.
Gitanjali Punj wrote:
> Can you tell me how to convert an ecore model to xsd through emf UI?
Re: xsd export [message #603371 is a reply to message #75996] Fri, 24 October 2008 06:54 Go to previous message
Gitanjali,
Previous Topic:xsd export
Next Topic:Is XSD2Ecore able to handle *.xsd files with multiple depedencies ?
Current Time: Fri May 24 13:27:23 EDT 2013
Powered by FUDForum. Page generated in 0.10215 seconds
