Home » Eclipse Projects » Virgo » error when installing Snaps 3.0.2 on VTS 3.0.2(error when installing Snaps 3.0.2 on VTS 3.0.2)
error when installing Snaps 3.0.2 on VTS 3.0.2 [message #759831] Wed, 30 November 2011 04:09 Go to next message
hserai is currently offline hserai
2011-11-30 00:57:26.651] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2011-11-30 00:57:26.842] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:57:27.040] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.snaps.api' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.520] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.580] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.snaps.api' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.583] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.587] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:57:27.605] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:57:27.609] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.snaps.api' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.625] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.628] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.snaps.api' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.771] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.775] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:57:27.778] system-artifacts <DE0501E> Cannot deploy artifact from URI ''. Deployment of 'null' URIs is not supported.
[2011-11-30 00:57:27.782] system-artifacts <UR0002E> User region failed while deploying initial artifacts. Shutting down.
[2011-11-30 00:57:27.862] System Bundle Shutdown <KE0010I> Shutdown initiated.
[2011-11-30 00:57:28.005] System Bundle Shutdown <TC0002I> Stopping Tomcat.
[2011-11-30 00:57:31.029] System Bundle Shutdown <TC0003I> Stopped Tomcat.
I am following the snaps installation instructions from the virgo documentation resources.
The log file doesnt have much information about the problem either:
[2011-11-30 00:51:49.840] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:51:49.840] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=org.eclipse.virgo.snaps.core_3.0.2.RELEASE]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-11-30 00:51:49.844] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:51:49.847] ERROR system-artifacts org.eclipse.virgo.medic.eventlog.default DE0501E Cannot deploy artifact from URI ''. Deployment of 'null' URIs is not supported.
[2011-11-30 00:51:49.850] ERROR system-artifacts org.eclipse.virgo.medic.eventlog.default UR0002E User region failed while deploying initial artifacts. Shutting down.
[2011-11-30 00:51:49.856] INFO System Bundle Shutdown o.e.v.kernel.dmfragment.internal.ApplicationContextShutdownBean Setting timeout to 0 for proxy 'org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean@557555b8' of application context 'OsgiBundleXmlApplicationContext(bundle=org.springframework.osgi.extender, config=bundleentry://79.fwk389362249/META-INF/spring/extender/kernel-dmfragment-context.xml): startup date [Wed Nov 30 00:51:44 PST 2011]; root of context hierarchy'
Re: error when installing Snaps 3.0.2 on VTS 3.0.2 [message #759951 is a reply to message #759831] Wed, 30 November 2011 11:42 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
I just tested snaps and it worked as expected on my setup.
Judging from the exception message it is possible that initialArtifacts is not correct. Can you post the userregion configuration (org.eclipse.virgo.kernel.userregion.properties)?
Have you tried to start Virgo with "-clean"?
Re: error when installing Snaps 3.0.2 on VTS 3.0.2 [message #759963 is a reply to message #759951] Wed, 30 November 2011 13:01 Go to previous messageGo to next message
I have tried -clean a few times but that doesn't work. Anyone know why VTS will through this kind of error? I am trying to understand what exactly it is complaining about...
Here is the edited portion of my 'org.eclipse.virgo.kernel.userregion.properties':
# the next line must not be broken with back-slashes
initialArtifacts=repository:plan/org.eclipse.virgo.kernel.userregion.springdm, repository:plan/org.eclipse.virgo.web.tomcat, repository:plan/org.eclipse.virgo.snaps
I am running on MAC 10.6.8, java version 1.6.0_29
Re: error when installing Snaps 3.0.2 on VTS 3.0.2 [message #759967 is a reply to message #759951] Wed, 30 November 2011 13:20 Go to previous messageGo to next message
I did a clean install of both VTS and snaps. Everything is working now...
Re: error when installing Snaps 3.0.2 on VTS 3.0.2 [message #759989 is a reply to message #759967] Wed, 30 November 2011 14:30 Go to previous message
Adding a comma in intialArtifacts reproduces the problem:
initialArtifacts=repository:plan/org.eclipse.virgo.kernel.userregion.springdm, repository:plan/org.eclipse.virgo.web.tomcat, repository:plan/org.eclipse.virgo.snaps,
The same effect can be achieved with additional comma:
initialArtifacts=repository:plan/org.eclipse.virgo.kernel.userregion.springdm, repository:plan/org.eclipse.virgo.web.tomcat,, repository:plan/org.eclipse.virgo.snaps
The URI is indeed "null" Smile
[Updated on: Wed, 30 November 2011 14:53]
Report message to a moderator
Previous Topic:Virgo 3.0.1 greenpages 2.4 build problems in STS 2.8
Next Topic:Is Virgo web container capable of using OSGI bundles?
Current Time: Sat May 25 17:12:49 EDT 2013
Powered by FUDForum. Page generated in 0.09674 seconds
