Home » Eclipse Projects » Buckminster » How to discard qualifier
How to discard qualifier [message #759930] Wed, 30 November 2011 10:31 Go to next message
Christian Pontesegger is currently offline Christian Pontesegger
Member
Qualifier replacement works fine when I use eg:
qualifier.replacement.*=generator:buildTimestamp
I was wondering if there is a way to discard the qualifier completely without touching the plugin manifests.
With the build timestamp I was able to set it to some fixed value like this:
generator.buildTimestamp.format='fixed'
but an empty format string would not work.
Any ideas?
Re: How to discard qualifier [message #759960 is a reply to message #759930] Wed, 30 November 2011 12:34 Go to previous message
Thomas Hallgren is currently offline Thomas Hallgren
> Any ideas?
If possible, the simple solution is to strip the .qualifier from your versions. That way, no generator will be called in
order to replace that key word.
- thomas
Previous Topic:Update Workspace
Next Topic:How to get Qualifier from build
Current Time: Fri May 24 11:44:36 EDT 2013
Powered by FUDForum. Page generated in 0.01554 seconds
