Home » Eclipse Projects » BIRT » Birt platform problem when rendering charts
Birt platform problem when rendering charts [message #759757] Tue, 29 November 2011 15:43 Go to next message
Anton is currently offline Anton
I have two scenarios:
1) Render a chart to an image
2) Load a rptdesign file, read a chart and render it to an image.
I have described a problem with the rendered image in scenario 1) in a
previous post.
In scenario 2) I don't even get to render the image, the application fails
in this line:
gcs = gr.build(dServer, chart, bo, null, null, null);
with the error:
org.eclipse.birt.chart.exception.ChartException: CREATE_EXTENSION_FAIL
org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObject(PluginSettings.java:1257)
org.eclipse.birt.chart.util.PluginSettings.getRenderer(PluginSettings.java:563)
org.eclipse.birt.chart.render.BaseRenderer.instances(BaseRenderer.java:2214)
at org.eclipse.birt.chart.factory.Generator.build(Generator.java:1060)
Caused by: org.eclipse.birt.core.framework.FrameworkException:
org.eclipse.birt.core.framework.eclipse.EclipseConfigurationElement.createExecutableExtension(EclipseConfigurationElement.java:39)
org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObject(PluginSettings.java:1253)
... 38 more
Caused by: org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.birt.chart.engine.extension was unable to load class
org.eclipse.birt.chart.extension.render.Line.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:904)
org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
org.eclipse.birt.core.framework.eclipse.EclipseConfigurationElement.createExecutableExtension(EclipseConfigurationElement.java:35)
... 39 more
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.birt.chart.engine.extension (29).
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:121)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
In scenario 2) the code that loads the rptdesign file is in one project and
the code that renders the chart is in another project. When I load the
rptdesign I set the BIRT_HOME to my local birt rte:
try {
designConfig.setProperty("BIRT_HOME","C:\\birt-runtime-2_6_1\\ReportEngine");
Platform.startup(designConfig);
IDesignEngineFactory designFactory = (IDesignEngineFactory)
Platform.createFactoryObject(IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY);
IDesignEngine designEngine =
designFactory.createDesignEngine(designConfig);
session = designEngine.newSessionHandle(ULocale.ENGLISH);
} catch (Exception e) {
logEngineError(e);
In the code for rendering the chart I have tried various approaches:
PlatformConfig pf = new PlatformConfig();
//pf.setBIRTHome("C:\\birt-runtime-2_6_1\\ReportEngine");
// pf.setProperty("STANDALONE", true);
// Returns a singleton instance of the Chart Engine
ChartEngine ce = ChartEngine.instance(pf);
IGenerator gr = ce.getGenerator();
But I get the same error. Any ideas why my application fails when I start
with loading a rptdesign file?
The jar: org.eclipse.birt.chart.engine.extension_2.6.1.v20100902.jar is both
on the build path (added as a maven dependency) of my project and in the:
C:\birt-runtime-2_6_1\ReportEngine\plugins folder.
Maybe its related to this post:
http://www.eclipse.org/forums/index.php/mv/tree/157384/#page_top
Re: Birt platform problem when rendering charts [message #759769 is a reply to message #759757] Tue, 29 November 2011 16:43 Go to previous messageGo to next message
I have nailed down to where the error occurs. At runtime I update some
values on a Series object with a NumberDataSet:
Double[] arr = new Double[values.size()];
for (int i = 0; i < arr.length; i++) {
Float val = values.get(i);
if (val != null) {
arr[i] = new Double(val);
NumberDataSet seriesValues = NumberDataSetImpl.create(arr);
EList<Series> series = seriesDef.getSeries();
Series serie = series.get(0);
serie.setDataSet(seriesValues);
testChartRender(chart);
when I try to render the chart after the serie.setDataSet(seriesValues) call
I get the error. The dataSet:
DataSet dataSet = serie.getDataSet();
is null. But why does the call:
prevent the chart from being rendered and why such a wierd error message?
"Anton" wrote in message news:jb3g59$fs8$1@news.eclipse.org...
previous post.
in this line:
with the error:
... 38 more
... 39 more
Caused by:
try {
logEngineError(e);
Re: Birt platform problem when rendering charts [message #759950 is a reply to message #759769] Wed, 30 November 2011 11:37 Go to previous message
js Missing name is currently offline js Missing name
Member
I have solved the problem my removing the chartdeviceextension and the chartengineextension libs from my dependencies. They should only be referenced from the birt rte.
[Updated on: Wed, 30 November 2011 11:39]
Report message to a moderator
Previous Topic:TUBE CHART NULL VALUES
Next Topic:Significance of engine parameters
Current Time: Sat May 18 22:52:18 EDT 2013
Powered by FUDForum. Page generated in 0.01578 seconds
