Home » Eclipse Projects » Eclipse 4 » Problem on Css styling the composite
Problem on Css styling the composite [message #759805] Wed, 30 November 2011 02:25
Jin  is currently offline Jin
I'm new to E4 and met a problem on it's feature.
I've heard of that E4 could use the components class name as the selector.
So i've written a child class named DateFilterComposite which is extended to Composite, and tried to add css to style this components. However it not woks.
public class DateFilterComposite extends Composite
    public DateFilterComposite(Composite parent, int style, boolean showSearchRun)
        super(parent, style);
        Label test1 = new Label(this, SWT.NONE);
        Combo = new Combo(this, SWT.READ_ONLY);
DateFilterComposite {
    background-color: red;
Also tried
.DateFilterComposite {   background-color: red; }
, but not work either.
Could anyone help me out if style the created child composite via css is possible?
If possible, what the correct syntax would be.
If not, any other ways could set a style to the component - DateFilterComposite.
[Updated on: Wed, 30 November 2011 04:46]
Report message to a moderator
Previous Topic:PartSashContainer as child of PartStack
Next Topic:Running e4 as IDE causes curious errors
Current Time: Fri May 24 08:55:27 EDT 2013
Powered by FUDForum. Page generated in 0.01611 seconds
