| XSDResourceImpl [message #75925] |
Fri, 10 October 2008 00:28  |
gitanjali punj Messages: 59 Registered: July 2009 |
Member |
In the class XSDResourceImpl there is a method caled
findSchemas and handleSchemaElement.Can you please explain
the use/functionality of these methods.
Also in the method handleSchemaElement there is a method
parameter called boolean 'isMeta',what does it signify?
| Re: XSDResourceImpl [message #75965 is a reply to message #75925] |
Fri, 10 October 2008 07:18  |
Ed Merks Messages: 24530 Registered: July 2009 |
Gitanjali,
Comments below.
Gitanjali Punj wrote:
> findSchemas
Typically the schema would be the root element, but in a WSDL document,
there are embedded schemas. This method searches the DOM tree for
<schema> elements from the schema namespace.
That method is called for each <schema> element. An XSDSchema is
created and the <schema> element is associated with that XSDSchema
instance so that the correspond EMF XSD model can be created to
correspond to the structure specified in the DOM.
> Can you please explain the use/functionality of these methods.
> Also in the method handleSchemaElement there is a method parameter
In XSDSchemaImpl the framework needs to manage the special XML Schema
for Schemas, which is the meta schema for all instance schemas. This
schema defines all the built-in simple type definitions and those are
needed by all other non-meta schemas.
| Re: XSDResourceImpl [message #603361 is a reply to message #75925] |
Gitanjali,
Comments below.
> findSchemas
FUDForum. Page generated in 0.06024 seconds
