Home » Modeling » M2T (model-to-text transformation) » '.emtl' not found
'.emtl' not found [message #759530] Mon, 28 November 2011 20:19 Go to next message
Atif Javed is currently offline Atif Javed
I want to perform ACCELEO transformation from .mtl file instead of build (.emtl) file. Because, this plug-in is used as Executable Jar File (which have no bin folders).
Error:
java.io.IOException: 'ProjectName.PackageName.ACCELEOMainTemplateJavaFile.emtl' not found
My currently written code is (which is not working in that case):
ProjectName.PackageName.ACCELEOMainTemplateJavaFile generator = new ProjectName.PackageName.ACCELEOMainTemplateJavaFile(modelURI, targetFolder.getLocation().toFile(), getArguments());
monitor.worked(1);
String generationID = org.eclipse.acceleo.engine.utils.AcceleoLaunchingUtil.computeUIProjectID("ProjectName", "ProjectName.PackageName.ACCELEOMainTemplateJavaFile", modelURI.toString(), targetFolder.getFullPath().toString(), new ArrayList<String>());
generator.setGenerationID(generationID);
generator.doGenerate(BasicMonitor.toMonitor(monitor));
Any kind of help is appreciated.
Atif/
[Updated on: Tue, 29 November 2011 07:51]
Report message to a moderator
Re: '.emtl' not found [message #760083 is a reply to message #759530] Thu, 01 December 2011 04:13 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent Goubet
Hi Atif,
Whether it is from an executable jar or not, the generation must be launched from an emtl file. And Wether it has a bin folder or not, the emtl is there Razz. The emtl file is the compiled form of the mtl file, much like the class file is the compiled form of a java file. You have the .class, nothing prevents you from having the .emtl Smile.
The jar file should contain the .emtl file; you should not have anything to change in order for it to work : just create your Acceleo module, export it as an executable jar, and launch the generation from that jar.
Laurent Goubet
Obeo
Re: '.emtl' not found [message #760174 is a reply to message #760083] Thu, 01 December 2011 09:29 Go to previous message
Thanks you very much.
[Updated on: Sat, 03 December 2011 12:27]
Previous Topic:load profile
Next Topic:using acceleo to M2M
Current Time: Thu May 23 12:27:59 EDT 2013
Powered by FUDForum. Page generated in 0.01722 seconds
