Home » Eclipse Projects » Standard Widget Toolkit (SWT) » converting swt to awt image transparency problem
converting swt to awt image transparency problem [message #455154] Sat, 07 May 2005 13:31 Go to next message
Eclipse User
Originally posted by: jan.van-oosterom.demon.nl
When I convert a icon frow SWT to AWT the transparency is lost
anybody a solution?
I used the code from this snippet:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet156.java?rev=HEAD& amp;content-type=text/vnd.viewcvs-markup
available from:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/dev.html#snippets
(convert between SWT Image and AWT BufferedImage)
I changed the main method with this code to read a icon from my system
(icon for .torrent files).
Program program = Program.findProgram("torrent");
ImageData data = null;
if (program != null) {
ImageData imageData = program.getImageData();
if (imageData != null) {
data = imageData;
bye,
Jan
Re: converting swt to awt image transparency problem [message #455288 is a reply to message #455154] Wed, 11 May 2005 07:54 Go to previous messageGo to next message
Eclipse User
nevermind, got around it
Re: converting swt to awt image transparency problem [message #759278 is a reply to message #455288] Mon, 28 November 2011 03:59 Go to previous message
Viorel Hojda is currently offline Viorel Hojda
Hello. Can you tell me please, you got around it by implementing it in some other way (not converting SWT to AWT image) or you found a solution to this?
Thanks !
Previous Topic:Display#loadFont on gtk-linux
Next Topic:modifying ImageData on server ( headless mode)
Current Time: Sat May 25 17:19:24 EDT 2013
Powered by FUDForum. Page generated in 0.01587 seconds
