Home » Eclipse Projects » Rich Client Platform (RCP) » How to load a UI PlugIn by code without UI elements being already there
How to load a UI PlugIn by code without UI elements being already there [message #758929] Fri, 25 November 2011 05:39 Go to next message
Matthias Becker is currently offline Matthias Becker
i am just starting with RCP/OSGI and just ran into this Problem:
I have a main application that provides a log in dialog. Depending on the credentials of the user i want to provide different UIs. Example:
- Main Application
Provides the login dialog and calls the login handler of the different "base" plug ins
- AdministrationBase
Checks if the user has the necessary rights to use the Administration dialog. If so, loads the AdministrationUI
- AdministrationUI
Provides the UI for Administration
So far this works fine but when i start the Application all menu entries defined in the PlugIn.xml of the AdministrationUI are already there before the log in is performed. I set the start level to a value > 4 and autostart to false without success. It seems that eclipse already reads the plugin.xml. So how can i tell eclipse to load the xml only then when the AdministrationBase loads the corresponding UI?
Or do i have to do this by code? If so, how can i ensure that the advisor classes are correctly executed?
Matthias
Re: How to load a UI PlugIn by code without UI elements being already there [message #759042 is a reply to message #758929] Fri, 25 November 2011 14:00 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
You can use your login to set roles, an ISourceProvider to make that information available to the framework, and then use Activities/Capabilities and the enabledWhen element to hide the plugin.xml entries you don't want.
PW
Re: How to load a UI PlugIn by code without UI elements being already there [message #759223 is a reply to message #759042] Sun, 27 November 2011 14:36 Go to previous messageGo to next message
thanks for the reply.
OK, Is that even usable to the availability of whole perspectives/views? It seems not to but it also seems that it would violate a Eclipse paradigm...
Re: How to load a UI PlugIn by code without UI elements being already there [message #759356 is a reply to message #759223] Mon, 28 November 2011 08:31 Go to previous messageGo to next message
I'm not sure what you are asking here. Activities/Capabilities are part of the the workbench UI support, see http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fworkbench_scalability.htm
It's one way to hide views and actions from the user.
PW
Re: How to load a UI PlugIn by code without UI elements being already there [message #764220 is a reply to message #759356] Sun, 11 December 2011 12:38 Go to previous message
thanks for the replies. Your replies helped me to find a way how to accomplish what i want.
working with the Eclipse RCP framework is... complex Smile
Thanks!
Matthias
Previous Topic:Equinox P2 process fail in RCP Application
Next Topic:Extension Points: "Second instance" not available
Current Time: Wed May 22 23:00:47 EDT 2013
Powered by FUDForum. Page generated in 0.02470 seconds
