Home » Eclipse Projects » Libra » by using eclipse wtp3.3 create WAR product configuration,export war file,one error occurs
by using eclipse wtp3.3 create WAR product configuration,export war file,one error occurs [message #758469] Wed, 23 November 2011 06:50
terry  is currently offline terry
By using eclipse wtp3.3 create WAR product configuration,Export the file(XXX.WAR) and one error come out
this is the @dit.log
# 11-11-23 18:09:30
# Eclipse Compiler for Java(TM) 0.B76_R37x, 3.7.1, Copyright IBM Corp 2000, 2011. All rights reserved.
1. ERROR in D:\work\eoffice\src\com\yidatec\eoffice\startup\Application.java (at line 22)
Syntax error on token "}", { expected after this token
2. ERROR in D:\work\eoffice\src\com\yidatec\eoffice\startup\Application.java (at line 24)
return PlatformUI.createAndRunWorkbench(display,
new ApplicationWorkbenchAdvisor());
public void stop() {
Syntax error on token(s), misplaced construct(s)
3. ERROR in D:\work\eoffice\src\com\yidatec\eoffice\startup\Application.java (at line 26)
Syntax error on token "}", delete this token
4. ERROR in D:\work\eoffice\src\com\yidatec\eoffice\startup\Application.java (at line 28)
Syntax error on token "void", @ expected
here is the application class:
package com.yidatec.eoffice.startup;
import org.eclipse.equinox.app.IApplication;
import org.eclipse.equinox.app.IApplicationContext;
import org.eclipse.jface.window.Window;
import org.eclipse.ui.PlatformUI;
public class Application implements IApplication {
public Object start(IApplicationContext context) throws Exception
Display display = PlatformUI.createDisplay();
if (authenticate(display) != Window.OK) {
return IApplication.EXIT_OK;
// WorkbenchAdvisor advisor = new ApplicationWorkbenchAdvisor();
// Do nothing
private int authenticate(Display display) {
LoginDialog loginDialog = new LoginDialog(display.getActiveShell());
return loginDialog.open();
[Updated on: Wed, 23 November 2011 06:56]
Report message to a moderator
Previous Topic:"OSGI Bundle" facet should requires "Java" facet
Next Topic:By using warproduct, Compilation errors occurred during the operation
Current Time: Sun May 19 12:03:05 EDT 2013
Powered by FUDForum. Page generated in 0.08083 seconds
