Home » Modeling » OCL » operation return type as Tuple
operation return type as Tuple [message #754848] Fri, 04 November 2011 11:40 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising name
I want to create an ocl operation with return type as Tuple.
For example if we want Integer to be return type of operation then we do like
eOperation.setEType(EcorePackage.eINSTANCE.getEInt())
and when we want to have a class as return type then
eOperation.setEType(etypeClass);
i want to have operation's return type as tuple holding class object and integer togather.
Any idea?
Thanks!
Warmest Regards
[Updated on: Fri, 04 November 2011 11:41]
Report message to a moderator
Re: operation return type as Tuple [message #754860 is a reply to message #754848] Fri, 04 November 2011 12:44 Go to previous messageGo to next message
Axel Uhl is currently offline Axel Uhl
Member
Have you tried using org.eclipse.ocl.ecore.TupleType? It extends EClass. Its properties represent the tuple's components.
Best,
-- Axel
Re: operation return type as Tuple [message #754880 is a reply to message #754860] Fri, 04 November 2011 13:57 Go to previous messageGo to next message
You will probably also want values.
You may find
org.eclipse.ocl.ecore.tests.RegressionTest.test_product_126336() and
org.eclipse.ocl.ecore.tests.CollectionsTest.test_tupleWithCollectionLiteralPart_175490()
are a source of useful example usages.
Ed Willink
> Best,
> -- Axel
Re: operation return type as Tuple [message #757780 is a reply to message #754860] Mon, 21 November 2011 11:07 Go to previous messageGo to next message
Thanks for help!
I am using the following code but when i try to parse the OCL operation it gives parse exception.
EOperation eOperation = EcoreFactory.eINSTANCE.createEOperation();
TupleType tt = org.eclipse.ocl.ecore.EcoreFactory.eINSTANCE.createTupleType();
EAttribute eAttribute1 = EcoreFactory.eINSTANCE.createEAttribute();
EAttribute eAttribute2 = EcoreFactory.eINSTANCE.createEAttribute();
eAttribute1.setEType(EcorePackage.eINSTANCE.getEString());
eAttribute1.setEType(EcorePackage.eINSTANCE.getEDouble());
tt.getEStructuralFeatures().add(eAttribute1);
tt.getEStructuralFeatures().add(eAttribute2);
eOperation.setEType(tt);
can you help me finding the problem?
Best Regards,
Re: operation return type as Tuple [message #757875 is a reply to message #757780] Mon, 21 November 2011 13:26 Go to previous messageGo to next message
You only provided half an example. When reporting an exception quote the
exception. I get no trouble from
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EOperation;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.ocl.ecore.TupleType;
public class Geek {
public void test() {
TupleType tt =
I suspect you made the wrong import decision on one of
EcorePackage/EcoreFactory/TupleType.
Ed Willink
> TupleType tt =
Re: operation return type as Tuple [message #758173 is a reply to message #757875] Tue, 22 November 2011 03:53 Go to previous messageGo to next message
Here is complete code and exception:
EAnnotation eAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
eAnnotation.setSource("http://www.eclipse.org/emf/2002/Ecore/OCL");
eAnnotation.getDetails().put("body", operation.getBody());
eOperation.setName(operation.getName());
eOperation.getEAnnotations().add(eAnnotation);
OCL<?, EClassifier, EOperation, ?, ?, ?, ?, ?, ?, Constraint, EClass, EObject> ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
OCLHelper<EClassifier, EOperation, ?, Constraint> helper = ocl.createOCLHelper();
OCLFunction operation = null;
helper.setOperationContext(eClass, eOperation);
try {
String body = eOperation.getEAnnotations().get(0).getDetails().get("body");
helper.createBodyCondition(body);
} catch (ParserException ex) {
ex.printStackTrace(); }
org.eclipse.ocl.ParserException
at org.eclipse.ocl.internal.helper.OCLHelperImpl.propagate(OCLHelperImpl.java:403)
at org.eclipse.ocl.internal.helper.OCLHelperImpl.createBodyCondition(OCLHelperImpl.java:263)
at abstractmodeller.model.prm.ECoreGenerator.validateOCLOperation(ECoreGenerator.java:651)
at abstractmodeller.model.prm.Prm.parsePOClFunctionsForPrmClass(Prm.java:792)
at abstractmodeller.view.canvas.controllers.PrmClassWidgetController.parsePOCLFunctions(PrmClassWidgetController.java:338)
at abstractmodeller.view.canvas.dialogs.POCLFunctionsDialog.init(POCLFunctionsDialog.java:190)
at abstractmodeller.view.canvas.dialogs.POCLFunctionsDialog.<init>(POCLFunctionsDialog.java:92)
at abstractmodeller.view.canvas.PrmClassWidget.executePopupMenuChoice(PrmClassWidget.java:495)
at abstractmodeller.view.shared.components.PopupMenu.actionPerformed(PopupMenu.java:219)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1223)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1264)
at java.awt.Component.processMouseEvent(Component.java:6267)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6032)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2478)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: java.lang.NullPointerException
at org.eclipse.ocl.ecore.internal.OCLFactoryImpl.createTupleType(OCLFactoryImpl.java:153)
at org.eclipse.ocl.AbstractTypeResolver.createTupleType(AbstractTypeResolver.java:403)
at org.eclipse.ocl.AbstractTypeResolver.resolveTupleType(AbstractTypeResolver.java:385)
at org.eclipse.ocl.AbstractTypeResolver$ResolveSwitch.caseTupleType(AbstractTypeResolver.java:1008)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitch(TypesSwitch.java:260)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitchSuperTypes(TypesSwitch.java:111)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitchSuperTypes(TypesSwitch.java:116)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitch(TypesSwitch.java:99)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitch(TypesSwitch.java:84)
at org.eclipse.ocl.AbstractTypeResolver.resolve(AbstractTypeResolver.java:127)
at org.eclipse.ocl.AbstractTypeResolver$ResolveSwitch.caseCollectionType(AbstractTypeResolver.java:1003)
at org.eclipse.ocl.types.util.TypesSwitch.doSwitch(TypesSwitch.java:161)
at org.eclipse.ocl.util.TypeUtil.resolveType(TypeUtil.java:617)
at org.eclipse.ocl.parser.AbstractOCLAnalyzer.getOCLType(AbstractOCLAnalyzer.java:4423)
at org.eclipse.ocl.parser.AbstractOCLAnalyzer.prePostOrBodyDeclCS(AbstractOCLAnalyzer.java:969)
at org.eclipse.ocl.parser.OCLAnalyzer.parsePrePostOrBodyDeclCS(OCLAnalyzer.java:290)
at org.eclipse.ocl.internal.helper.HelperUtil.parseBodyCondition(HelperUtil.java:284)
at org.eclipse.ocl.internal.helper.OCLHelperImpl.createBodyCondition(OCLHelperImpl.java:260)
... 34 more
[Updated on: Tue, 22 November 2011 03:56]
Re: operation return type as Tuple [message #758188 is a reply to message #758173] Tue, 22 November 2011 04:41 Go to previous messageGo to next message
This is still not complete code (where are the imports?)
You have added additional Java lines which completely change the
question; previously it was a simple Java coding problem, now there is
some OCL parsing, but you do not provide the OCL or the referenced models.
The stack trace clearly shows an NPE at OCLFactoryImpl.java:153, that on
the current code base is
Environment<?, C, O, P, ?, ?, ?, ?, ?, ?, ?, ?> env =
Environment.Registry.INSTANCE.getEnvironmentFor(parts.get(0));
which looks suspiciously like Environment.Registry.INSTANCE is null,
since parts is an EMF collection that is never null. But INSTANCE has an
initializer so it too should never be null. You need to do some
debugging. Perhaps you are using older code and the line number aligns
differently. It always helps to specify a code version.
Background: Tuples and Collections are awkward because specializations
have to be created and contained somewhere. OCL provides a default
internal package for them, but if you serialize the OCL you must take
responsibility for their containment; I doubt you're serializing, so you
can ignore doing this.
Ed Willink
On 22/11/2011 08:53, ModelGeek wrote:
> TupleType tt =
> try {
> String body =
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 34 more
Re: operation return type as Tuple [message #758211 is a reply to message #758188] Tue, 22 November 2011 06:01 Go to previous messageGo to next message
I have tried to check and i have found that Environment.Registry.INSTANCE is not null but Environment.Registry.INSTANCE.getEnvironmentFor(eClass) gives null.
And i am not doing serialization.
When i try to create an ocl operation with return type not as tuple type then everything works fine, the parsing works fine as well.
Do you have any clue? what is going wrong
Thanks alot for helping
[Updated on: Tue, 22 November 2011 06:48]
Re: operation return type as Tuple [message #758240 is a reply to message #758211] Tue, 22 November 2011 07:26 Go to previous messageGo to next message
I have solved it, i added
Environment.Registry.INSTANCE.registerEnvironment(ocl.getEnvironment());
and it operation parsed perfectly.
THanks for help!
Re: operation return type as Tuple [message #758305 is a reply to message #758240] Tue, 22 November 2011 11:49 Go to previous message
Well done for finding a workaround/fix. It doesn't seem right to do
something to a global registry, and it doesn't seem right that you
should need to do so at all.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=364493 raised, though
since it's on the legacy code, I can't be sure if it'll be resolved.
Ed Willink
On 22/11/2011 12:26, ModelGeek wrote:
> THanks for help!
Previous Topic:[Announce] Eclipse OCL 4.0.0 (Juno) M3 is now available
Next Topic:How to initialize the attributes of variables in an OCL query
Current Time: Fri May 24 21:11:46 EDT 2013
Powered by FUDForum. Page generated in 0.08153 seconds
