| Re: Exception: Could not create the view [message #758255 is a reply to message #758248] |
Tue, 22 November 2011 08:12  |
Eric Clayberg Messages: 737 Registered: July 2009 Location: Boston, MA |
I don't see anything WindowBuilder related in this report. If you are having a runtime problem with SWT or RCP, you should post your question (and test case) to the Eclipse SWT or RCP forum. You should also include the complete stack trace (not a screen shot).
Without a test case (actual code) and the full stack trace, I don't see how anyone would be able to help you other than to tell you that you have some unknown problem with your UIMockUp class.
FUDForum. Page generated in 0.05495 seconds
