Home » Eclipse Projects » BIRT » Oda Customer Connector setup(Having issues getting a report to locate my custom connector class.)
Oda Customer Connector setup [message #757651] Mon, 21 November 2011 01:00 Go to next message
pgittings  is currently offline pgittings
I'm a Java/Eclipse/Birt newbie (more familiar with C#), and I'm having an issue with creating a custom connector for a web service data store.
Background:
I'm trying to get to a point where I can use BIRT to generate reports from a IIS hosted web service. The web service expects authentication, as far as I've been able to figure out the BIRT web service data sources doesn't support authentication thus the need for a custom connector; if anybody else has a solution they would be willing to share I'd be very grateful.
Where I'm at:
I've crated two projects, one contains the report the other contains a package with my custom connection and query class. In the DataSource I've specified the ConnectionClass Property Binding to point to my custom connection class: packageName.ConnectionClassName.
In the report project properties I've added the custom connector project to the Report Design/Classpath. I also added it under the Report projects' Project References.
However when I click on the report preview, the result is a java.lang.ClassNotFoundException and it names my custom connector class.
So what step have I missed to get the report to pick up custom class?
Paul
Re: Oda Customer Connector setup [message #758096 is a reply to message #757651] Mon, 21 November 2011 16:13 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Paul,
Are you using this approach?
http://birtworld.blogspot.com/2009/12/birt-designer-classpath-changes.html
What version are you using?
Jason
On 11/21/2011 1:01 AM, pgittings wrote:
> Background:
> grateful.
> Where I'm at:
> Paul
Jason Weathersby
BIRT Exchange
Previous Topic:Is it possible to remove postscript option in Export Format window?
Next Topic:Trying to Sum the distinct values
Current Time: Mon May 20 01:12:20 EDT 2013
Powered by FUDForum. Page generated in 0.19961 seconds
