Home » Eclipse Projects » EclipseLink » Re: Descriptor Events on Entities which have not been modified during a Transaction
Re: Descriptor Events on Entities which have not been modified during a Transaction [message #758011] Mon, 21 November 2011 13:24 Go to next message
James is currently offline James
Why don't you use the @OrderColumn?
Or, can you maintain the index in your model, just update the index every time you add or remove from the collection, such as defining add/remove methods on your class.
For using events, why would you want events from objects that did not change?
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Re: Descriptor Events on Entities which have not been modified during a Transaction [message #758196 is a reply to message #758011] Tue, 22 November 2011 04:59 Go to previous message
JFK Missing name is currently offline JFK Missing name
Thanks again James.
The reason for the example was to see whether there were any other techniques that could be used to manage a collection of objects which derived state from their position in a List. The reason for not doing this at the time of inserting/removing other items is just that it means doing it all the time, not on some final event. Before I rewrote this I wanted to make sure I was not missing something that I could get for free from Eclipselink, I wasn't sure from the docs whether the PreWrite event was available on all Entities or not.
Its not an issue and I can see the benefits/difficulties of calculating the changes once and not firing events on unchanged entities.
Previous Topic:Descriptor Events on Entities which have not been modified during a Transaction
Next Topic:not persisted values are lost when cloning
Current Time: Mon May 20 18:39:02 EDT 2013
Powered by FUDForum. Page generated in 0.08340 seconds
