Home » Modeling » TMF (Xtext) » Grammar rules ordering
Grammar rules ordering [message #757603] Sun, 20 November 2011 04:59 Go to next message
Mahmoud Moneeb is currently offline Mahmoud Moneeb
I wondering does the ordering of two ORed rules make a difference ?!
for example:
Rule: rule_1 | rule_2 ;
Is it supposed to work the same as
Rule: rule_2 | rule_1 ;
I have tried implementing some grammar rules and I found that the ordering of the ORed rules matters.
Mahmoud
Re: Grammar rules ordering [message #757604 is a reply to message #757603] Sun, 20 November 2011 05:17 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
can you elaborate a bit on what happens when you change the order in a real world example.
it should not matter if there are not any ambiguities in your grammar.
~Christian
Re: Grammar rules ordering [message #757606 is a reply to message #757604] Sun, 20 November 2011 05:28 Go to previous messageGo to next message
At first I had this rule and it was not working as expected
primary :
prim_res = ID
| literal
| function_call
| aggregate
| qualified_expression
| name
| allocator
On changing the order of the rules It works fine now
primary :
function_call
| prim_res = ID
| literal
| aggregate
| name
| allocator
Another example :
the second rule here is always not working. Only the first one get recognized by the generated IDE
logical_expression :
LHS_relation = relation ( Multiple_logical_operators REST_RHS_relation += relation )*
| LH_relation = relation ( Single_logical_operators RH_relation = relation )?
Re: Grammar rules ordering [message #757608 is a reply to message #757606] Sun, 20 November 2011 05:39 Go to previous messageGo to next message
As i said: you grammar is ambigous => first come first serve
[Updated on: Sun, 20 November 2011 05:44]
Report message to a moderator
Re: Grammar rules ordering [message #757612 is a reply to message #757608] Sun, 20 November 2011 05:51 Go to previous messageGo to next message
So how can I detect the ambiguous points in my grammar exactly and there no warning and the building went smoothly ?!
I'm talking in general. Maybe I face other problems with the grammar later and need a way to resolve these ambiguity issues
Mahmoud
Re: Grammar rules ordering [message #757613 is a reply to message #757612] Sun, 20 November 2011 05:55 Go to previous messageGo to next message
you have to enable backtracking to get the grammar built - so you actually get warned
~Christian
[Updated on: Sun, 20 November 2011 05:58]
Re: Grammar rules ordering [message #757614 is a reply to message #757613] Sun, 20 November 2011 05:57 Go to previous message
P.S: you might have a look at assigend actions to build proper expressions see http://blog.efftinge.de/2010/08/parsing-expressions-with-xtext.html
Previous Topic:[Xtext 2.1.1][SOLVED] create custom loop scope
Next Topic:a type serializer for JvmType
Current Time: Sun May 19 05:17:34 EDT 2013
Powered by FUDForum. Page generated in 0.01997 seconds
